Question about Denon AVR-987 Receiver
How do i hook an i-pod to my denon-AVR3801. Headphone jack? If so what function?
I'm assuming you want to play your i-pod through your reciever? If so, you need a male stereo mini to dual male RCA Y-cable (follow the link at the bottom for an example). The mini end goes into your i-pod. Plug both RCA's into the CD or PHONO inputs on the left side, center, as you face the rear of your reciever. Left(L) is usually white or grey and right(R) is the other color, usually red or orange.
I hope this gets you started. Ask again if you have more questions.
http://www.bestbuy.com/site/olspage.jsp?skuId=7005457&type=product&id=1099392032460&ref=06&loc=01&ci_src=14110944&ci_sku=7005457
Posted on Dec 03, 2008
I have a Denon avr 391 and it worked fine for 4 years. Now I cannot get any sound out of it. Any idea what's going on. Help
could be a bad headphone jack. There was a commong problem with denon receivers around that time where the headphone jack had contacts that would short and make the unit act like there were headphone plugged in even when there wasn't. Sometimes you can clear the error by inserting a headphone plug and unplugging it a couple times. If it continues to happen, then you can get the headphone jack replaced.
Jan 04, 2015 | Denon Avr-391 Av Home Theater Receiver
How can I connect my I pod Touch to my Denon AVR 1803 reveiver?
Connect the 3.5mm cable to the iPod headphone output and the two RCA plugs into any unused analogue audio input on the Denon AVR 1803. Then choose the appropriate input on the Denon, press play and enjoy the music. Be careful about volume. Start with the volume on the iPad low and adjust to suit.
Cheers, Don.
Aug 07, 2014 | Denon AVR-1803 Receiver
Hp input cycles on and off and there's no volume on my denon aver 1610 receiver
Headphone jack is bad. Two ways to fix: Either replace the headphone jack, or if you don't plan on using the headphones, unplug the cable going to the headphone jack pcb. There may be two cable on that board, unplug the one that is closest to the front panel. This will affect nothing else except disabling the headphone jack.
Mar 05, 2013 | Denon Audio Players & Recorders
Denon 1908 no sound
Try inserting a headphone plug into the headphone jack and remove it. Sometimes these units have a problem in the headphone jack where the unit thinks there are headphones plugged in even when there isn't. This cuts all the audio output to the speaker jacks. If you never plan on using the headphone jack, you can also go inside of unit and unplug the cable that goes to the headphone jack board. Just make sure you unplug the unit before you do this, the plug is close to the main power switch.
Feb 22, 2013 | Denon AVR-1908
Denon Receiver keeps switching between H/P input and speakers
The problem may be dust in the headphone jack
http://blog.adamnash.com/2010/10/01/solution-denon-av-receiver-avr-1410790-with-no-sound/
Jun 17, 2012 | Denon AVR-1709 Receiver
Hook up an iPod to Beosound2000 system??
There is an Aux input on the B & O. you can connect the I-pod to through this input. You will need a 3.5mm phono to 2 RCA cable connector. The phono jack goes to the I-pods headphone socket and the RCA ( Red & White ) jacks goes to the B & O Aux input.bobhifi_28.jpg
Apr 01, 2011 | Audio Players & Recorders
I just bought a I Pod dock ASD 11R and would like
Get a 3.5 plug with two RCA plugs and connect it to an aux imput via the headphone out of the dock.
Jan 24, 2010 | Denon AVR-3803 Receiver
How do i cnnect an ipod to a bose am plus 100 business amplifier. we have one at my job but their are no standard inputs
Does your bose amp. has an headphone input?
If it those,get a jack head that has a small like the size of your i pod head phone space.(small jack to jack cable).
Connect one of the jack heads to your i pod and the other to your amp.
Check if your amp. as any of this functions it,(aux,tunes,phone,video).
click on any of their functions.
But make sure your speakers are connected properly to your amp. try it out it will work.see yah
Jan 18, 2010 | Audio Players & Recorders
Stopped consistently producing sound
Try plugging and unplugging a pair of headphones. The headphone jack in these receivers are flaky and sometimes think there are headphones hooked up even when there isn't. Full repair would require the headphone jack to be replaced. If you don't use headphones at all, you can take the top cover off and unplug the cable going to the headphone jack board and eliminate the problem that was as well.
Mar 01, 2017 | Denon AVR-1603 Receiver
Denon AVR-987 Receiver Logo
43 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
