Question about Hardware & Accessories
First Alert Timer ET220
How do you set it? We want to use it for indoor christmas lights as soon as possible.
I can't find any instructions online (lots of links to spyware, but no legit sites)
First Alert doesn't seem to have any instructions on their site, just features and pictures.
  • 2 more comments
  • sashaspapi Dec 06, 2008
    I need instructions also to set the First Alert Timer ET220
  • Anonymous Dec 10, 2008
    need help setting and working timer
  • Anonymous Jan 28, 2009
    i have the same problem
  • Anonymous Mar 16, 2009
    Same problem here.
1. Set time: Rotate dial (PM indicated by PM
light) Stop at current time. Press Time set
button.
2. Rotate dial to desired ON time; press & hold
On/off button, rotate dial to OFF time, release
On/off button
3. To Cancel the time.. Press & Hold on/off and
rotate one cycle to erase. and will have to
rest time (1)
Posted on Jul 28, 2009
  • 1 more comment
  • PoppaKen Dec 09, 2011
    Of the three button cell batteries, what is the polarity?
  • PoppaKen Dec 12, 2011
    Easiest to follow, but haven't succeeded so far.
OK, try this.
Remove batteries for a minute or two to clear memory. Replace batteries.
1. Plug into wall
2. Hold down ON button for 5 seconds to turn on
3. Rotate timer to correct time, hold TIME SET button for a few seconds until the light flashes
4. Rotate knob until first desired on time. Hold down ON button
5. While holding ON/OFF button rotate timer to desired off time, then release ON/OFF button.
6. Repeat 4 and 5 for second time
7. Plug in lamp and test.
I think that's close, I'm testing ours tonight.
Posted on Sep 01, 2009
    Hasn't worked so far.
    Problem Solver:
Remove the button cell battery holder.
Look inside the space, where the holder was.
Negative is on the right and Positive is on the left.
It is shown, but is very hard to see.
Posted on Dec 12, 2011
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Have a first alert et220 timer. After setting it and turning back to current time, pm light goes out and clock does not run. Manual switch works fine
Timer is not identified for certain. Expert does not have instruction manual and can only guess at cause of problem.
For example not all timers are rated for CFL or halogen bulbs.
Loose light bulb filament, or loose light bulb, or dirt in light bulb socket can cause problem, replace light bulb.
Conflicts in timer programming can cause problem with digital timer.
Read more options listed below:
1) Add a comment and describe timer appearance and if timer is programmable or has a rotary dial.
Describe what buttons appear on timer.
2) Take photo of timer and post on flickr and add comment with link to that photo.
3) Scan your timer instructions into file format. Post this file to Flickr and then add a comment with link to those instructions.
Sep 09, 2011 | First Alert 24 Hour Timers - 2 For The...
I have the first alert timer model et220 and i have no instruction with it. could you provide me with instructions on setting the timer?
Question does not describe the timer.
Web search for et220 does not show image of timer for clear identification.
My files do not show et220
Question posted under 24-hour analog timer.
1) Open following link for possible instructions:
http://www.fixya.com/support/t1329823-first_alert_timer_et220
2) Add a comment with clear description of timer for possible identification and instruction manual.
3) Post a photo of the timer on Flickr. Add a comment with link to photo for possible identification and instruction manual.
4) Maybe possible to e-mail the company for instructions: orders@vwimc.com
Sep 08, 2011 | First Alert 24 Hour Timers - 2 For The...
HOW DO YOU SET UP THE ET220 TIMER IT WILL NOT WORK
Solution posted at:
1. Set time: Rotate dial (PM indicated by PM light) Stop at current time. Press Time set button.
2. Rotate dial to desired ON time; press & hold On/off button, rotate dial to OFF time, release On/off button
3. To Cancel the time. Press & Hold on/off and rotate one cycle to erase.
And will have to reset time (1)
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 23, 2010 | First Alert 24 Hour Timers - 2 For The...
I lost instructions for setting my 111 Woods timer. It is used indoors. Please send me instructions Thank you and have a merry Christmas
Merry Christmas to you also.
I do not show a Woods 111 timer.
However Woods is sold under many different numbers and a few different brand names.
Link below goes to all Woods timers and manuals:
Step 1) Scroll through page and look carefully at the timers to help identify your timer. Similar timers might set the same way as your timer. Add a comment any time.
Step 2) Add a comment and describe your indoor timer. Is it wired into the wall, or does it plug in. Describe the buttons in detail or the dial, describe override switch if it has one. Give as much information as you can think, and then I will check other resources
Step 3) Check list of other brands because Woods carries over into other brands as well. I am familiar with these timers.
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
Dec 10, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Need instructions to set this timer
You posted under a photo that looks like Woods/Coleman cable 2001/49647 timer
See image at Amazon
http://www.amazon.com/dp/B00002NB2X/ref=asc
If this is not your timer, see all Woods timers and manuals at following link:
Manual for Woods 2001-49647
http://waterheatertimer.org/pdf/Woods-2001-49647.pdf
Instructions:
Plug in timer, plug lights into timer, capacity 1875 watts
50-mini-bulb string of Christmas lights is 25 watts
Timer tuns ON automatically at dusk
Use dial to set 4 possible options:
Off = always OFF
ON - always ON
Dusk-Dawn = ON at dusk, OFF at dawn
2,4,6,8 hours = ON at dusk, lights OFF 2,4,6,8 hours later
Dec 09, 2010 | Woods Outdoor Lighting Timer
Need operating instructions for First Alert timer ET220.
Feb 18, 2009 | Hardware & Accessories
How to program Intermatic model T101-70
Do you have the screw on trip pieces? They look like little arrows with a thumb screw on them. Some of them should say On, some Off Place the on trips over the time you want the lights to com on vice versa for off. To set the time pull out on the yellow time wheel and rotate until the arrow that is pointing down is over the current time. I hope this helps.
Nov 21, 2008 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
5,484 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
