Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine Kenmore 3.2 cu ft Super capacity plus top loader
My washer starts fills up but does not wash at all.I had to remove the clothes in it and drain it mannualy.Can this be the timer?
  • 3 more comments
  • Siafu Mar 29, 2008
    I have a Whirlpool LSR8433KQ1 top loader that just stop working this afternoon. We purchased it in 2004 from Lowes. The first load went through fine. The second load was set on medium the basin filled with water. Once the lid was closed it stopped. I turned the machine on and off with the dial still nothing. I thought it was the outlet. Changed the plug to another outlet and turned the dial to rinse. The water came on then stopped again. The original outlet still worked. I removed the clothes and made sure there was nothing caught in the agitator and tried turning it on again to no avail.
  • shinypurple Jun 19, 2008
    I have exactly the same problem. I blew into the pressure switch, but now it doesn't stop filling with water! I'm draining all the water out & then I'll try again...
  • b0hunt3r39 Dec 14, 2008
    I have the same problem, I emailed cat directly hoping for some help, I blew into the pressure switch as well and no wash cycle so I open to anyone who can help me. This is an 80 series super capacity plus
  • Anonymous Mar 23, 2014
    Sounds like a "machine gun" when filling drum on 5.1 cu ft front loader
    softner drains out when filling
    President:
  • 878 Answers
Fabi, if Im reading you right the machine fills with water and just sits there. Can you hear the motor running when it should be agitating? If so you might have a broken coupler. If the machine is quiet and just sits there, it could be the pressure switch. The first picture shows the pressure switch with the rubber hose and purple wire going to it (far left). There is no model number posted but this is a top loading Kenmore, should be close. Take the rubber tubing off the switch and blow into the switch with another piece of tubing. Does it start agitating? If so, there's your problem. If you do hear the motor running and it's not agitating it may be the motor coupler. If you need more assist...email me at catriver1@gmail.com Catriver..post back.
Posted on Feb 05, 2007
  • Ron Marek
    Ron Marek Feb 05, 2007
    This is the coupler
  • Ron Marek
    Ron Marek Feb 08, 2007
    Dinoza, thanks for the kind words, if you ever need any help, you can e-mail the cat here at catriver1@gmail.com
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Catriver I've been reading your answers for a while. you are amazing!
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
How do you remove the top off the washing machine to replace the lid switch in a kenmore super capacity 80 series?
The following link explains step-by-step how to replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Oct 26, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine keeps draining during rinse
You may be experiencing a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Apr 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
What is the capacity of my Kenmore washer?
3.2cu ft.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Are you happy with the Kenmore 800 4.0 cu.ft. top load washer?
For large capacity, a front loader would be your best bet. An HE2 by Kenmore should be sufficient. If a toploader is overloaded, it's more likely to do damage. Also a Whirlpool Duet would work. Whirlpool makes Kenmore, so shop for the best price, (they are the same inside)
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
1,284 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
