Question about Jl Audio 1000/1 Car Audio Amplifier
JL Audio 1000/1
Whenever the amp is powered on the yellow "low Ohm" light comes on and stays on, have now wired up two sets of JL Audio 12W6v2's. One is my brothers configuration in his truck. The other is my personal set that has had no issues before.
  • 62 Answers
Check the resistance between the positive and negative terminals of the speakers. There should be atleast 1 ohm of reistance depending on your set up... if there is very little there is a short in your wiring. If not remove the wires from the amp and now check the resistance between the termanls on the amp...there should be no condinuity...if there is your amp has short circited out.
Posted on Mar 26, 2007
SOURCE:
JL Audio 1000/1 v2 distortion problem
Make sure all your connections are tight , really tight . Check ground , make sure it's to clean shiney metal. Three subs are going to have a low ohm load if paralleled . These amps are not 1 ohm stable ,if below 1.5 ohm's you will have problems. They need to be series paralleled to raise the ohm load. These amps put out the same power from 4 to 1.5 ohms.
Mar 14, 2012 | Jl Audio Car Audio & Video
I looked up the correct way to wire my JL 13.5W7 1.5. Therefore it said to wire it in parrallel. I understand this will put it at .75 ohm. As I start to turn it up it sounds great, very loud but once the...
1000/1v2 Class D Monoblock Subwoofer Amplifier Specifications:
  1000/1v2
Rated Power:
1000 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio:
>95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response:
5 Hz - 250 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm / 50 Hz
According to the chart your amp is only stable down to 1.5 Ohms, so running at .75 Ohms the noise you are hearing is the amp clipping (running more power than it can handle at low ohms)
I would suggest wiring it in series, or you could adjust the gain on the amp until the popping goes away.
Hope this helps.
Nov 10, 2010 | Jl Audio 13W7 Car Subwoofer
I have 2 jl audio 12w6 and one jl audio 500/1 amp, and the speakers make a weird noise..sounds like the voice coils are bad..so my question, is there any way i can fix them or i need new speakers?
yeah you can always take it back to your local JL audio dealer, i wouldnt do it your self unless you done it before and got it down like a ****. A lot of people i know tryed and always ending up tossing it out.....
May 07, 2010 | Jl Audio 12W6 Car Subwoofer
When i turn the volume up my jl 1000/1 amp turns off then turns back on when the volume is low what can i do to fix this?
2 things, either your pushing too much power into the imputs (if using high inputs) and clipping the signal, or your running the ohms too low (lower then the amp can handle safely) by running multiple speakers of too low an ohm each. For example if your amp is 4 ohm stable and your running 2 4 ohm speakers in parallel that makes 2ohms and the amp can't handle a load that low. You can consult your manual and it will give you illistrations of wiring and ohm loads
Oct 26, 2009 | Jl Audio 1000/1 Car Audio Amplifier
What would be a better amp for my jl audio 12in w6v2
its not the amps my dude ur ohm loading is wrong if u have a 4 ohm stabled amp n ur speakers r 2 ohms naw thats not gonna fly caus it cant put out what ur asking 4 so u need 2 reload ur subs try this link http://www.bcae1.com/spkrmlti.htm this should help u out n save u money
Jun 17, 2009 | Jl Audio 12W6v2 Car Subwoofer
Low ohm light stays on my jl 1000/1
you have your amp wired at too low of an ohm load for the amplifier. This is why it is doing this. Jl amps are awesome and pretty much make everything idiot proof. Not calling you an idiot but go online and search for that model on JL.com then look on either the box your subwoofers came in or on the back of your subwoofers. Find out which ohm load they are and how many voice coils. Next go to www.the12volt.com and find the subwoofer wiring diagrams close to the top of the page. Then enter in your information on your sub's impedence and how many you have then it will give you the wiring options that you have and it will probly tell you you are wired at like a .5 ohm load. And let me guess you turn it up too long or too loud and your amp gets hot and it goes into protection.
Jun 09, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Low ohm light comes on and loud humming sound comes from amp and sub have a j1000 and 13 w7
nice set up, how many speakers are you running? you have something wired up weird causing the ohm level to drop to low. we can fix this let me know and ill help you.
Mar 07, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 10w6 x zapco350
These subwoofers are dual 4 ohm voicecoils.
Parallel wiring the 2 voicecoils would net a 2 ohm mono load.
Connect both + on the sub to the + on the amp.
Connect both - on the sub to the - on the amp.
Many professionals simply jumper the 2 + and 2- on the sub.... then run 1 set of wires from one of the terminals to the amplifier.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Jl Audio 12W6v2 Car Subwoofer
Low ohms light ! ! ! !
How are the speaker wired and what is the ihms for the speakers?
Dec 06, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
271 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
matthew walsh
Level 1 Expert
Dalynn Turner
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
