Question about Memorex Televison & Video
HELLO, I HAVE A MEMOREX MVDR2100 DVD VIDEO RECORDER THAT WILL NOT TURN ON. THE FUSE SEEM TO LOOK AND TEST GOOD,BUT NO POWER GETTING TO THE SWITCH. I HAVE TRYED THE RESET IN THE INFO MANUAL. THANK YOU, JERRY
  • Jerry Vitzthum
    Jerry Vitzthum Dec 04, 2008
    I HAVE CHECKED ALL THE EASY THINGS, EVEN THE FUSE IS GOOD. WILL THE REMOTE WORK IF THE SWITCH ON THE UNIT BAD??
    Genius:
  • 1,239 Answers
HI YHER MAY BE ONLY 2 PROBLMS 1.fuse,,but you said i already checked it.then it is conformly  2.the wire,,,,,there may be any burnt region in wire connection due to high voltage or any loose connection wire
so make a test with multimeter....check whether the wires are ok....
Posted on Dec 04, 2008
  • 4,234 Answers
These units use a switch m ode power supply and these are not the easiest to repair. I have seen a number of these fail. If you can solder and have access to a few spare parts, you can try to repair this. There will not likely be any parts that appear defective. Try replacing the caps on the primary side (160-200V caps). If replacing those does not resolve the problem, look for Zener diodes on the secondary side that may be shorted.
Dan
  • 4,806 Answers
Hello Jerry.
You have done everything it tells you do in the manual, if the DVD is still under warranty take it back to be repaired, or you will have to remove the lid of the DVD player (screws at the sides/back) have a look inside the player for an internal fuse that may have blown, these are pretty easy to replace when you find it
Kind regads
Posted on Dec 03, 2008
  • 6,487 Answers
It seems that thjis is already a hardware problem and needs some part replacement , So I suggest you just take this to a repair center or have it replace if its still under warranty...
    Sergeant:
  • 217 Answers
Check out the power wire is it ok or got cut in between.also check out the board of the device if any component short on the board it will have no power.
MVD2050 will not turn on. We have a DVD stuck in it. We turned the power off and back on after 60 minutes but nothing happens.
Hello K4, hi you can manually get the disk out, but you need to remove the cover. As for the power thing, you have a power supply problem, would you like to service it yourself or call a technician, If you will service it yourself, this are the things you should check:
  1. fuse
  2. open wirings
  3. shorted or over heating rectifier diodes and voltage regulator
  4. bulging filter capacitors
  5. Switching regulator IC, check for the output pulse using a scope.
  6. replace the bad parts, then test.
Apr 28, 2010 | Memorex MVD2050-BLK DVD Player
It wont turn on even when pluged in
I recommend removing the cover. Check too see if the glass fuse inside is bad. There should be a thin wire inside the fuse that runs all the way across it. It is broken or burnt, then it's bad.
If the fuse is good, then you may want to get a voltmeter and test the power going from power supply (power converter) to the main circuit board. Make sure the reading is the same as the label on the back of the player that says DC Voltage Output. If not, it is bad.
Apr 19, 2010 | Memorex MVDR2100 DVD Recorder
Stops recording in middle of my video
try another media (i like verbatum)
Its not unusuall to get a bad batch of disk from Memorex or Maxell
May 13, 2009 | iLO DVDRH04 DVD Recorder
DVD recorder wont record
The instruction manual says it strongly recommends for good quality recording : Sony Maxell and TDK and has been been tested for Verbaitim as well.
Nov 11, 2008 | Funai TruTech DVDVCR Dual Recorder
I don't have disc to download my memorex dvd recorder to my laptop computer.
Using a USB port might be a good idea, and an installation disc isn't necessary. ...accordianman
Jul 30, 2008 | Memorex MVDR2100 DVD Recorder
Memorex DVD Player
hello...please contact her dealer and try to replace the recorder if ther's a warranty...if not refere to the user manual.,and carefully read it regarding first useage...please tell me how it went...good luck...Ron
Mar 07, 2008 | Memorex MVDR2102
Interface error! Trun off the power
Okay...sounds like you have a lot of signal splitting as well as devices that may also weaken your signal. With digital cable, you won't see snow or what would be a dead give-away to a weak signal. Only analog signals do that. Digital signals give you crisp clear picture or they drop out.
Try taking the cable directly from the wall to the DVD-Recorder. If you are able to watch channels and manipulate the device, then you can start from there as the source is good and the recorder is good.
Try to place the DVD-Recorder after the first splitter and see if you still receive stable signal. You'll probably need to leave the unit in this part of your A/V chain.
It really sounds like you need a signal amplifier for all the splitting you've done, or to re-work your A/V stack into something more manageable. It is entirely possible that the built-in tuner of the new DVD-Recorder is not as sensitive as the old unit.
Oct 28, 2007 | Memorex MVDR2102
Mini DVD Camcorder Problem
You will never be able to recover the information. Sony's system really will have problems with third party brands; there is particular engineering that makes this so. In my shop (Sony authorized), I have seen this problem many times. If you insist on using other brands, get used to problems. As your laser assembly wears it will become more problematic. Good luck, magic seadog
Jun 14, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Televison & Video Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
