Question about Canon EOS-1Ds Mark II Digital Camera
Focusing screen fell out
The little rectangular screen fell out and I have no instructions for putting it back in. THe manual just refers to 'the manual that came with the new focusing screen', which I don't have, since this is the original that came with the camera, I am not sure what to do? thanks
  • Anonymous Sep 30, 2008
    the focusing screen on my eos 400d also fell out all to gether 4 pices fell out i sent it to be repaired when it came back the auto focus dident work so i had to get the new eos 450d. i still live in hope that it can be fixed as its still under a year old.
    j evans
There is a metal cradle inside the camera in the roof that flips down. Try firing the shutter without a lens attached, you'll be able to see the rectangular cradle(Tray) The Focusing screen is to be placed in the roof of the camera with the small tab facing OUT of the camera,.be sure to press in firmly with some pressure, but ensure that you support the tray while you do this so as not to damage it.do not touch the main part of the focusing screen Focusing screens get damaged very easily. Try only to touch the tab(make sure your hand is not making direct contact with the screen, as i learnt mine the hardway, you can wear apair of clean surgical gloves) The Cradle then lifts upwards and clicks in. Also note the lock in tab that holds the tray in place and check to see that its not slack, if it is, the tray will drop back halfway after firing the shutter and lifting the cradle/tray. to correct this, slightly push it in & fire the shutter again until you get the right amount of grip nd your tray stays up after the shutter is fired. It worked well for some time until it fell out again and irepeated the procedure above and added this time some very thin line of glue around the edge of the screen to keep it in place. Dont use epoxy based glues like super glue et al.
Posted on Mar 03, 2009
There is like a metal cradle inside the camera in the roof that flips down. The Focusing screen is to be placed in the roof of the camera with the small tab facing OUT of the camera. The Cradle then lifts upwards and clicks in.
do not touch the main part of the focusing screen. Try only to touch the tab
Focusing screens get damaged easy
Posted on Mar 17, 2008
Have 2003 ford focus dohc. part of exhaust system fell off. from back to front I have 1. tail pipe 2. rectangular box shaped part 3. missing part
I see a visit to a muffler shop in your future. Find an independent privately owned shop, not a chain operated place. They'll be better and cheaper than a chain shop
Jul 02, 2017 | Ford Cars & Trucks
Optical viewfinder vignette problems
Sound like the focus screen and frame fell out
Mar 22, 2012 | Canon EOS 5D Mark II Digital Camera
We have just bought a house in Canberra with a Honeywell Thermostat to operate gas central heating system. There is no manual and we do not know how to programme it. I would guess that it is about 10 years...
I have put many of those in and yes, they are hard to program compared to the new ones. You will probably not find any instructions unless you go on line to honeywell and ask. Otherwise it may be worth your time and less head ache to just go get a new thermostat even the ones at Home Depot are a lot easier.
Apr 08, 2011 | Honeywell Heating & Cooling
The shutter inside fell out.
You must be referring to the mirror. In the second part, you must be referring to the focusing screen. If you have not dropped it, there is no likelihood of this getting damaged. You could probably be looking at the split image screen. There is no quick solution for the problem. Please take the camera to the nearest service center.
Jan 29, 2009 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Frame around lens fell off
Do you mean the focussing ring fell off?
It can be reglued with Superglue, but be very careful not to use the glue from the tube or you could get it everywhere. First focus the lens on infinity. This is the furthest back or most withdrawn position of the lens. The infinity marking on the ring will be beside the diamond or dot indicator. Put a little bit of Superglue onto the end of a matchstick, and then use the matchstick to put traces of the Superglue on the lens barrel, exactly where the ring will sit. carefully place the ring on its correct position on the lens barrel.
May 27, 2008 | Casio Exilim EX-S500 Digital Camera
FOCUS ERROR
I also had this problem. When starting the focus error alert came. Trying to move the focus button also triggered this. When I turned it off, the lens did not pull back.After being close to trowing it away, I used a little bit more force than before and turned the lens manually. I heard a click, and than it worked again. PS: Follow this tip on your own risk.....
Mar 11, 2008 | Fuji FinePix F410 Digital Camera
I have an alignment problem with colors and i've found a little mesh screen
yr previous buld is it burn out or explode ?
if explode might be the tiny glass neeed to service (cleaning)
please do a tilt correction
do manually
Mar 08, 2008 | InFocus Proxima DP6155 Multimedia...
Digitil camera out of focus
The motor that controls the focus of the lense may be bad. Here is a link to the manual, and you many need to have the camera serviced at a local shop or by Vivatar.
Go here to download the manual for future reference:
http://www.vivitar.com/ecms.aspx/e65dedb4-5c74-4e09-8110-95947ea5f876/SupportFiles/ViviCam3713.pdf
Apr 12, 2007 | Vivitar ViviCam 3710 Digital Camera
Canon EOS-1Ds Mark II Digital Camera Logo
123 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
