Question about Acer Computers & Internet
Ok so i was cleaning out some files and some how messed up my default settings for my desk top, now my images are bigger than they should be and they are stretched and distorted, i have tried everything i can think of to try and fix it but i think i just keep making it worse can you please help me??
    Genius:
  • 1,061 Answers
CLICK ON YOUR DESKTOP...CLICK PROPERTIES ...CLICK SETTING 1024X 768 ETC.AND CLICK APPLY.RICHARDM69
Posted on Dec 03, 2008
I cant bring up google anything from toolbar or desk top
check your settings. look for your new tab and or your home page as it may be getting a redirect command from these points. also your default search could also have been effected. these problems may be from a malware/virus that hit you and was deleted. Some of your main settings may have been changed and/or you may have lost some system files that run your browsers. I always download at least 3 browsers onto all of my PC's and Laptops that I fix. In case you lose one you can still get online to fix the others. you can also set up another Admin account that you only use in case of messed up system settings in your main account! I hope I have helped.
Oct 05, 2014 | HP Computers & Internet
I did copied an image from a book so i want to make it bigger
You need photo editing software, like free Gimpshop.
Go to Gimpshop and download program:
This is a very good photo editor, and it's free.
http://www.gimpshop.com/
1) After the download, You have to open gimpshop once so a shortcut appears on desktop.
So go to start, all programs, and look for GIMPshop, and put mouse on GIMPshop, and box appears, and then click on GIMPshop located in that box.
Gimp opens. The close Gimp and see there is a desktop icon.
2) Find the image you want to make bigger.
Hover mouse over your image without clicking mouse, and the size of image will show in small box. For example it will show Dimensions: 1000 x 700
Write down the size
3) Drag and drop your image on top of gimp icon and program will open.
4) Once photo is loaded.
Go to 'Image' at top of program and select 'image size'
You will see numbers for width and height appear in small boxes.
Use your mouse and keyboard to change the numbers and double the size.
For example make new dimensions 2000 x 1400.
Or make it 3 times bigger.
Then click 'scale'
5) You will see the image is bigger.
6) Time to save larger image.
Go to 'File' at top of program
Click 'save a copy'
Box comes up with name. Re-name the image so it does not replace original.
Click save.
7) another box comes up with a 'quality' slider
Move slider to 100%
Click OK
8) Bigger image is saved and ready
Mar 05, 2011 | Cycling
I purchased the sylvania 7in netbook for my daughter and when I was having problems with it, I saw that going to digitalgadgets.com had an upgrade and when I loaded the upgrade into my memory card and...
Is your machine comming on at all? You may have just wiped out the icons on your Desk Top.
If you can click on start, click on run, type desk top into the open space and ok it. your icons should be shown. you will have to copy and paste each one back to your desk top, or select edit and then select select all, then click on file, select send to, and select desk top as short cut.
Dec 07, 2010 | Sylvania G-Netbook
My picture size have gone from an average 3.1mb to 1.6mb for the last few days. But the resolution is same-8mp-3264 * 2448....settinga are not changed.....set to their default.....in automode....picture...
If you are in Auto mode, try go to menu and change the "Image Quality" from normal to fine. The file size should then be bigger as the image compression ratio is less.
Oct 18, 2010 | Nikon COOLPIX P60 Digital Camera
A photo I saved onto my Pictures file off the internet now appears on my desk top on top of my desk top image. I csn't get rid of this picture. How can I return my Samsung Netbook to factory settings?
right click on your desktop and go to properties, Click on the desktop tab and change your wallpaper to whatever you want. If you dont see a pic you like in that list click on browse to find the one you want.
Mar 28, 2010 | Computers & Internet
ACER ASPIRE 3000
What new softwares or updates have you just done on the Aspire 3000,You need SP 2 Updates to function properly...
Change cmos back to default and then reboot
don't touch cmos anymore
FOLLOW THESE STEPS
after start up.
go to desk top
right click on the desk top
properties
display properties opens on themes
select settings
Now with Both screens attached and powered up
box 1 displayed will allow you to adjust the properties here.
Adjust to the smallest settings first should be 800x600
and this will allow you to independantly set sizes of image for each screen.At 800x600 both screens will be identical in size in the menu box.
Screen Number # 1
click Idendify,& number 1 should appear on your screen
click advanced
select compatibilty click apply without restart and OK
Screen Number # 2
DO the same process as Screen Number # 1
image size here needs to be 800x600 too
If your video does not run it will be the screen settings I have just talked about unless you have other softwares as a default.
Remove the other softwares and try again.
You should be able to save the settings for a dual output or set output to individually operate either or.....
I hope this helps your situation,
Please rate me or if you need more help just ask thanks
Jun 21, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
