Question about Panasonic CT-32D30 32" TV
My Panasonic Television
I have a Panasonic Television (standard) 32" Model CT 32D30 of which I have owned for almost 5 years. I turned it off after the morning news and when I returned and turned the power back on the sound came in clear, but the picture did not come in. The only thing on the screen was a a thin line with different color pigments running through the middle. The television was not moved, and had nothing done to it or around it. I am not sure if I need a new lamp, bulb, or tube. Could somebody help me? Thank you in advance
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Fixya is an excellent site!
Posted on Feb 05, 2007
    Scholar:
  • 119 Answers
Sounds like you either have a bad vertical deflection ic, or a bad resistor supply power to the ic. i'me not sure of the location, but panasonics usually put it in ic401.it is a ic with 10 to 16 pins all in a row. it will ne screwed to a small heatsinkthe making on the ic should start with laXXXX. x being numbers. good luck
SOURCE:
Panasonic CT-32SL14J green picture after blown fues replaced
no there may be loose contact or dry solder in circuit board attached to tube..ie video driver section ..resolder
all the solder joints cleanly...&also resolder the long ic ie
chroma ic...u can find where the problem is by gently tapping the main board or video board by a tooth brush
when tv is on. if the color changes by tapping u can get the loose contact..have a nice day
Mar 10, 2010 | Panasonic CT-32SL14 32" TV
Television problem
HELLO!!
FROM WHEN ARE U FACING THIS PROBLEM ???
Dec 30, 2007 | Panasonic CT-36HL43 36" TV
I have a panasonic 32'' hdtv that may need a thermistor
there is a diode gone bad in the power supply have a tech come out and replace it
Nov 24, 2009 | Panasonic CT-32HXC43 32" TV
Power just quit had a great picture
panasonic tv's suffered from frame chip problems causing them to be stuck in stand by .not an expensive part though...
Apr 25, 2009 | Panasonic CT-32SL14 32" TV
Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
Is this?
This is from page 5 of the Operating Instructions:
TV set can
receive 480i signal only.
This means the television is NOT high definition, it is a STANDARD definition television.
Mar 15, 2008 | Panasonic CT-36SL13 32" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
CT32SX12F 32" Won't power on
when mine it, i had to replace a fuse
Jan 05, 2008 | Panasonic CT-32G11 32" TV
Panasonic CT-32D30 32" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
