Question about AMD BOSTAR M7ViZ Socket A Motherboard (MBM7VIZ)
Wires off to the front panel for controls ext need to know what g
Spk wires hdd ect dont know where they go pls help
  • 341 Answers
I dont know how to fix the Front Panel Audio Connector. And I dont understand what is ATX power switches. I'll tell you what wire i have: H.D.D. LED, POWER LED +, POWER LED -, RESET SW and POWER SW....
You have to make make the four Front Panel Connection as shown below: -
(IDE LED is the same as HDD LED and Ground means negative '-')
Hope it helps! Good Luck!
Thanks for using Fixya!
May 31, 2011 | ASUS P4VP-MX Motherboard
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
Pulled off front cover. three sets of wires came off. need to know where to reconnect. white/red wire HDD LED, white/green wire POWER LED, white/black wire POWER SW
Hi. You may want to check your motherboard for this wires to connect to, First, check your motherboards manual and look where the FRONT PANEL is located, then on the front panel or in the manual itself it will tell you where are those wires should be connected to. If you dont have the manual for your motherboard search it on google and do the same, and if still you coudnt find it over the internet then just look closely on your motherboard and look for the words HDD LED, POWER LED and POWER SW, usually those words or the FRONT PANEL is located on the left side bottom part of your motherboard. Hope This Helps
Jun 09, 2010 | E-Machines T3302 PC Desktop
Need plug wiring diagram pioneer deh-46dh
Orange-12v all the time
Red-igintion switch
Yellow- to lighting switch terminal
Black- chassic grd
Green-front L spk +
Green/black -front L spk -
Gray - F R +
Gray/black- F R -
Green/red- R L +
Black/green- R L -
Gray/red- R R +
Black/gray- R R -
Blue- Control to power amp if using.
Apr 10, 2010 | Pioneer DEH-46DH CD Changer
I need the diagram for 1993 honda accord for radio i am installing a jvc cd player and i dont have the right adapter so i cut the origanal plug and now need to know the color codes for the wiring
this the wiring for that car--
constant power-white/green
ignition--white with red
left front spk-blue with green-+
left front spk-ghray/black -
right front spk-red/gree-+
'' spk-brown/black-
right rear spk-red/yellow-+
'''''''''''''''''''' spk-brown/white-
left rear spk-blue /yellow-+
'' spk-gray/white -
antenna you done need you antenna is in your window
Jun 25, 2009 | Car Audio & Video
A power diagram for restoring power for a emachine
Hi there if you look real closley at the wires they are labled such as (pwr)led (reset) (hdd led )
(remote switch this the power for the computer) ect ect now look real closley and you will see the same markings on the edge of the board by each pin that they go to.. or you can also contact e-machines tech support and they will be able to help you out more if needed
best regards mike
Mar 17, 2009 | E-Machines eMachines Desktop PC
Connect wires to the motherboard
Please tell me the model number then I will be able to help you.
Nov 14, 2008 | E-Machines eMachines Desktop PC
Power switch
You could try searching for the manual for the motherboard, I have the same problem every time I disconnect a motherboard.
Sometimes it is printed on the motherboard in dead small writing which wire goes where.
Also usually motherboard manufacturers follow the "unofficial" standard io connectors.
PLED = Power LED/Message LED
HDD = Hard Drive LED
RST = Reset Switch
PSW = Power Switch
SPK = Speaker
NC = Not connected (sometimes not even there)
Note quite often the Reset switch is the reverse of everything else! (i.e. on most if the + is on the right the + is on the left for the Reset
The USB ones usually always follow the following standard
And usually one of the NC pins is no pin as some USB cables have that pin blanked out to ensure you connect them the right way. Note also with USB you start with the VCC then you go straight to negative data, then positive, then ground (again the - and + data bits, like the reset are in reverse of normal reading - the are right to left, not left to right!)
Finally if your not sure which cable is + and which is - the - ones are normally either black or white (most of them are white, except the speaker ones which are black - I presume that goes back to the colour scheme of red and black for positive and negative in audio equipment) and the + ones are normally some colour.
Dec 11, 2007 | Abit nForce2 NF7-S2 Motherboard
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
AMD BOSTAR M7ViZ Socket A Motherboard (MBM7VIZ) Logo
55 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
