Question about Viking VESO176 Stainless Steel Electric Single Oven
Lengthy preheat time
It seems to take an extraordinary amount of time - 20-30 minutes for the oven to preheat and then it sems to be cooking at a lower temperature than the setting. We are near sea level, but following cooking time directions results in undercooked dishes. The oven is about seven years old and was in the house when we bought it.
    Scholar:
  • 82 Answers
Hello. I am a Viking factory trained tech. and that is actually a normal preheat time.
Now if it undercooks that is another problem.
You may need your thermostat calibrated or replaced. If you think you are up to calibrating it yourself let me know. If it is the kind that doesn't have any white silicone in the center of the knob stem then it is quit a pain in the neck, but if it does have the silcone then it is a lot easier.
Posted on Dec 03, 2008
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Need to know the cooking time and temp in C in fan forced oven for pork loin roll weighing 1.22kg
    usually 40 minutes per 500 grams at 180 degrees C
    so 1 and a half hours plus preheat the oven .
    And it is thawed not frozen
    don't just take my word for it read it on link below
    http://www.pork.com.au/home-page-consumer/recipes/cooking-instructions.aspx
    Dec 24, 2016 | Ovens
    Thermador oven preheat light will come back on during cooking session. The clock has also stopped working.
    There may be a fault with the control board.
    http://appliancejunk.com/forums/index.php?action=dlattach;topic=9146.0;attach=5091
    Oct 05, 2014 | Thermador Ovens
    General Electric oven how to reset thermostat
    First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
    Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
    My oven bakes, but it takes 30 minutes to preheat
    Hi friend, thank you for your post!
    I know from your post that your Frigidaire oven is working but the preheat takes 30 minutes. This does sound like lengthy amount of time for preheat to be completed. From what you are describing it could be an issue with the panel, element, or thermostat. Since it could be anyone of these underlying issues I would recommend having a professional come out to diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts. -Matt
    Aug 06, 2014 | Frigidaire 30 in. Electric Gallery Series...
    Temperature when using frigidare oven, keeps getting hotter and does not cool down
    Good Afternoon Andrea,
    I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
    I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
    -Best Regards-
    WP
    Apr 22, 2014 | Frigidaire Ovens
    I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
    I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
    I don't have a manual. and I've been searching for it...does anyone know which one I need?
    Sorry I couldn't help with your problem, mine is similar to your though!!
    Jan 22, 2011 | KitchenAid KEMC308K Double Oven
    I have a Maytag Advanced Cooking System (Super Capacity) gas stove. The oven takes an incredible amount of time to preheat & then smell an odor of gas. What could be wrong?
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    Oven Problems Replacing the Igniter
    heatman101
    Jan 04, 2011 | Maytag Ovens
    Viking VESO176 Stainless Steel Electric Single Oven Logo
    550 people viewed this question
    Top Viking Ovens Experts
    Dan Webster
    Dan Webster
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Viking Oven Expert? Answer questions, earn points and help others
