Question about Frymaster Dean Kitchen Appliances - Others
Please help where can i find a book on this? we replaced the gas valve (part#8071604 product#75008462 honeywell) with a 2 wire thermopile part# 205T102 i need to know how to wire this properly. thank you.
There is power going to the fryers but they will not turn on. what could be the problem??
Posted on Jan 03, 2009
  • 1,199 Answers should help! follow this link!
Posted on Dec 10, 2008
Is the honeywell wv8840B1109 like a smart meter. I was concerned after they installed this on my new water heater. It's basically an alarm for if the pilot shuts off. Seems awfully big to just be for that....
Thanks for photo link. Not a smart meter.
Just ordinary water heater gas control valve, with small circuit board to support error codes:
Copy following link for handy resources:
How the newer gas control valves are different: Old water heater had thermocouple which supplies very tiny current to gas control valve. When pilot light blows out, the thermocouple no longer sends tiny current and gas control valve shuts off gas to heater.
New gas water heaters have thermopile (just like modern furnaces and stoves), which is basically several thermocouples bunched together. So thermopile sends more current to gas control valve, and supplies enough current to power small circuit board. The circuit board records error events and issues simple error codes. If pilot blows out, then thermopile no longer sends current and gas control valve shuts off gas to heater.
Moreover, the new gas control valve can be repaired and replaced without removing from tank. So tank does not have to be drained... saving time and repair cost.
Aug 09, 2013 | Water Heaters
Pilot is on, thermostat click but the burner didn,t come on please help thank
Try to tighten wiring connections on gas valve, thermopile, hi limit and thermostat, if it does not correct the problem, try replacing the thermopile first then if the burner still do not fire up, replace the gas valve.
Apr 01, 2011 | Vulcan Kitchen Appliances - Others
Pilot light keeps going out! Will not stay Lit.
Check if the the gas pressure is sufficient (as stated on unit's nameplate). Check if the hi limit device is good. Check also if the thermopile (cylindrical metal with two wires standing behind the pilot hood) is receiving enough heat from the pilot flame. The voltage generated by thermopile should be 500millivolts in order to open pilot and main valve. If there is 500millivolt on gas valve thermopile and the pilot flame does not stay lit, you have to replace the gas valve. If the thermopile is glowing red and the voltage generated does not reach 500 millivots, you have to replace the thermopile.
Jan 18, 2011 | Pitco Frialator SG18S Deep Fryer
We changed the thermostat in our unit and now the pilot lite won't stay lit!
You have to check the following:
1. Does the pilot flame has the ability to heat up the thermopile? Themopile must be properly heated in order to generate voltage to open the pilot valve as well as main valve.
2. When the thermolpile is heated, does it generates 500 millivolts? If not, your thermopile needs replacement. If it does and still the pilot flame wont stay lit, your gas valve needs replacement.
3. Does the hi limit device has continuity on its terminals? If there is no continuity on hi limit terminals, you have to replace it. One of the thermopile wire passes on this hi limit terminal to cut the voltage supply on pilot valve in case the oil temperature reaches 450F.
4. Check and tighten all wiring connections, millivolts generated by thermopile will not pass on loosely terminated wiring.
Jan 12, 2011 | Pitco Frialator 35CS Deep Fryer
How do you check a thermopile? MY pilot is on but it wont light. I checked the manifold and its all cleared. Thinking its my thermoplie not telling the switch to open.
A thermcouple is what keeps pilot on, if your unit has both a thermocouple and thermopile then your pilot CAN stay lit and main burner not come not buy a gas vavle untill you check the thermopile voltage!! very costy blunder.this is how you test it..( open circuit test) Disconnect thermopile leads from valve. take a volt meter set it to millivolts- set it to a mv reading above 500 so that you can test it correctly, my meter has 2000 setting and I use that. connect T/P leads to meter leads.. reading should be 500mv.
( closed circuit test) connect leads of meter to terminals that your thermostat or on/off swich are hooked too, usually top and bottom terminals on most gas valves, turn unit on and reading should be 150mv or more... you need try open circuit. I can test your vavle too if you like keep me posted if I helped or not. 15 yrs experience in gas repairs!!
Feb 04, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
Heater won't light. Pilot on and good flow.
depending on how old the unit is it may have a thermopile "generator". the thermopile will have 2 wire leads that usualy attach to the main gas valve by 2 screws. set your multimeter to mvdc and tke a reading usualy anything over 350 mvdc will be able to energize the gas valve. any bad connections or open limits or safty switches will not alow the main gas valve to energize. hope this helps.
Jun 14, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Yes, hopefully changing the thermocouple (skinny sensor) or thermopile(fat sensor) would do the trick.
Start with these fairly inexpensive repairs first.
Unfortunately if the honeywell valve is bad a new one can be expensive.
Also it is hard to order parts from Majestic, they just went bankrupt, not to long ago and Martin is taking them over. You might look for your valves model# and check online for other suppliers of that model# or ask for a compatible Direct Vent gas valve that's not as problematic. (eBay and HVAC dealers, etc.)
You said it's been about 5 years, you might decide it's less of a hassle to have new gas fireplace installed. Martin and Empire are probably two of the best, with 5 year parts and labor warrantys.
Hope you find some success in your endeavor.
Dec 10, 2008 | Honeywell Electronic Programmable...
Pilot light will not stay lit
You can not check a thermocouple by resistence. You have to check it by millivoltage when it is hot and sensing it should be above 500mv. I would be willing to bet that you have some type of particulate in the gas valve that is causing this problem.
Jun 23, 2008 | Pitco Frialator SG14 Deep Fryer
Open Questions:
Kitchen Appliances - Others Logo
83 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
