System Issue My son put in his nintendogs cartridge and deleted his data and now when he turns on his system the power button comes on, but no screen shows up.
1. Power off the tablet.
2. Press and hold the Volume up button.
3. While holding the Volume up button, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4. Once the tablet screen turns on, stop holding the buttons.
5. On the Android system recovery screen, select wipe data/factory reset. Use the Volume up and Volume down keys to navigate through the menus and use the Power button to select the desired option.
6. When prompted to "Confirm wipe of all user data", select Yes -- delete all user data.
7. Select reboot system now.
Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button,Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished.
You need to do a factory reset, follow these instructions:
Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button. You should then see the screen below.
Alright, here is what you do. 1) make sure your system is off (solid red light) 2) hold down the power button (on the system not the controller), it will turn green do not take your finger off, wait for the light to turn back to red then take your finger off 3) hold down the power button again until you hear a quick double beep come from the system then take your finger off 4) if you did it right your system should say that you need to plug your controller in, follow the instructions on the screen 5) you should the see 6 options on screen, choose option 3 6) once that is finished let the system startup normally 7) got to the menu that says game, choos the option that says "Game Data Utility" (not "Saved Data Utility"!!!!) 8) find the data for your game, press the triangle button and choose delete (you shold not loose your progress if you do this right) 9) put your game disk back in and let the game data reinstall 10) your game should work after these steps are done correctly, if not call sony sonsumer services
To delete Nintendog data:On the DS home page, click on the Nintendogs game.When the 'Nintendo' screen pops up press the X,A,B, and Y keys, and the R and L buttons simultaneously.You should hear a ring and a message "Are you sure you want to delete data?'' Select yes and voilà!
When you turn the DS on, with Nintendogs in the console, touch the screen when H&S comes up. touch nintendogs, and when the Nintendo logo comes up, PRESS L, R, X, B, Y and a simultaneously.
You need to RESTORE FILE SYSTEM on your ps3. Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode). 2. Put out your usb cable for the controller and the controller itself (do not connect yet). 3. Hold down power firmly, ps3 will turn on and then turn off, release power button when it turns off. 4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button. 5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that. 6. After connecting the controller press PS button. 7. You are now in the recovery menu. 8. To fix the problem of corrupt data you can choose #3. 9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive. 10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
