Question about GPS
I have a Garmin c530 of which in a resent move has lost the car charger that came with it. Can you supply me with a replacement? COST? jmarsh12@cogeco.ca
  • 928 Answers
You may go to this site to purchase the items that you require.
https://buy.garmin.com/shop
Posted on Dec 03, 2008
How do you change lithium ion battery in garmin streetpilot c530
The unit can be opened by removing the frame around the screen. However if you are still under warranty you will void it. The battery is not an easily replaceable one since it is soldered into the unit but if you are hany with a soldering iron it is fairly straightforward. However you have to find the correct battery which you can do with an online search.
Nov 01, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin C530 won't power up. I fully discharged battery and recharged. Unit gets warm while charging, still won't turn on. Replaced battery, charged..gets warm...still won't turn on. Are there any other...
How old is it and does it get quite a bit of use
If so then consider replaceing the battery
Ebay has a good selection from a wide range of reputablesellers and very good prices
Check Here
Aug 26, 2009 | Garmin StreetPilot c530 GPS Receiver
My Garmin c530 GPS will not turn on
Pull the face off it, press the reset button, this may work,
If it will not reset, or work in the house or the car, the battery will need replacing,
http://www8.garmin.com/support/outofwarranty.html
Around $100 for new battery
Regards.
Jun 21, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin c530 powers up breifly then shuts down
The problem is with the battery, DC will not fully charge the battery to its required capicty to work. You need an AC charger and to charge it fully ( 10 hrs Max) and then try it. It needs a lot of power to drive the screen and connect to satellites.
Invest in an AC charger and all should work properly
Jun 07, 2009 | Garmin StreetPilot c530 GPS Receiver
Can't register my Garmin c530
Hi
You'll need to enter the serial number of your device, only after that you'll be able to select your c530 device from the list. However, if its not showing there then you can visit this link for update installation of your C530---
Garmin C530 Update
Garmin Product Registration Link
And, if you are unable to install the updates then you can visit this link for more details---
Garmin Support
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 29, 2009 | Garmin StreetPilot c530 GPS Receiver
Deleted memory for garmin c530
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. This would allow your to install new maps. You did not delete your internal memory, you deleted your internal maps. Moving the maps from internal to external memory cannot be done on your PC and have them work. They have to be installed on the SD card via Garmin Express. https://support.garmin.com/faqSearch/en-US/faq/content/b17m7lCO3R4UKUAt8x67J7
Mar 21, 2017 | Garmin StreetPilot c530 GPS Receiver
C530-Dead
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still exists then try to charge your gps from any external charger and check whether screen is working properly .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Dec 09, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin C530 need pin to unlock
Have you tried putting the unlock code in the main directory?  To do this open up notepad or some similar text program and copy the code from the yellow sheet onto the note pad and save it as GMAPPROM.UNL.  Then open "My Computer" and locate the Garmin removable device.  Open the "Garmin" folder and copy that file to it.  Safely remove it from your system and turn it on.
Nov 18, 2008 | Garmin StreetPilot c530 GPS Receiver
Reset my garmin streetpilot c530gps
There is no way to just "reset" the PIN. If you don't have the correct PIN, you must take the unit to the location at which the PIN was set. Your only other option is to return the unit to Garmin.
Feb 21, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530
Carefully remove face plate bezel. There is a reset button on the right side of the face. Press the button and then restart normally. It's in the owners manual if haven't lost yours like I did. The manual is on Garmins website.
Feb 16, 2008 | Garmin StreetPilot c530 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
