Question about Kenmore Elite 45986 Front Load Washer
Leaking front loader
My kenmore front loader is leaking..I think around the tub..whats wrong with it?
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Posted on Dec 05, 2008
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Sep 12, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Jan 31, 2010 | Kenmore HE2 Plus Front Load Washer
WATER COMING OUT UNDER MACHINE
Is this a TOP LOADER? Or, is this a FRONT LOADER?
If this is a Kenmore TOP LOADER, you will need to remove the exterior washer case to inspect the cabinet interior thoroughly to determine WHERE the leak may be coming from. The following link explains:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The most common source of leaks on a top loader is a worn drain pump. If the pump is damaged and leaking, it is not serviceable and must be replaced. There is a follow-on link included that explains how to replace one.
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior. The following link explains:
If you have any questions about these repairs, please post back with your complete MODEL NUMBER (located on a nameplate around the door or tub rim) so that I may be able to provide you with better assistance. I hope this helps you.
Jan 18, 2010 | Washing Machines
Kenmore 43042 front loader, black boot (?) twisted and loose
the black gasget on the inside of the door is suppose to be loose and flexible for sealing purposes.
when your washer went thru it's spin cycle is it possible the throw pillow got cought between gasget and wetal tub?
also is this the only time you noticed this ?
Oct 01, 2009 | Kenmore 46462 Front Load Washer
My kenmore front loader makes a knocking when it spins.
how old?sounds like the bearing are going bad,on yours the tub and bearing are one unit,so you have to change out the whole thing-mike
Mar 24, 2009 | Kenmore Elite 45986 Front Load Washer
Top load kenmore 110
it's your pump! thats the most common leak on kenmore top loaders.it located low ,front and .you can tip washer back towards wall and inspect.the pump is white and has two hoses to it.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
the most likley place is the front rubber boot it can get a small hole in it and leak if the hole is not to large you can clean and dry it and reseal it with silicon rubber sealent
Dec 03, 2008 | Kenmore 44102 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
163 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
