Question about Whirlpool 24 in. DU850SW - Multiple Color Free-standing Dishwasher
Won't start, made strange noise.
Cycle won't start, no water. makes very strange noise and then stops. It is very cold here, could my inlet be frozen? How would I check (all other water seems to be running okay.)
    President:
  • 878 Answers
JenZ, first check out the float assy. inside the tub and make sure that it is not stuck in the up position. If that is ok, you will have to remove the bottom panel and on the left you will see the fill valve. There will be a two wire harness going to it. You will have to see if you have power going to it when you start the dishwasher. If you have 120V. going to it and still no water, remove the water line to it and see if you have water. Shut it off at the supply first. If you have water and power and still no fill, replace the inlet valve...part number. 8283345. Catriver..post back
Posted on Feb 05, 2007
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Lg wf 801 won't fill
Yes , It can be related to the control board, but first of all please make sure that there is good water flows in both the inlets, check the flow after the valve , ensure that the inlet filters are not clogged and check all the connections from the harness to the valve and panel
Jan 19, 2013 | LG WM Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
Water flows constantly during the spin cycle
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced.
Dec 08, 2011 | GE WBVH6240F Front Load Washer
I just moved into a new apartment and used a moving company to help me with my move. that included my washing machine. i just went to turn it on to do a load and it won't start. i hear a humm noise but...
Hi
Make sure the water taps are turned on. The humming sound is most likely from your inlet solenoids.
Check both the hot and cold water inlet hoses going to the back of your machine. Make sure they are connected properly and that the water is turned on.
If still no joy let me know and I will guide you through more trouble shooting items.
Ash
Sep 02, 2011 | Whirlpool LSR5132PQ Top Load Washer
My washer wont fill with water what seems to be the problem
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 10, 2011 | Samsung WF210AN Washer
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
May 30, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Whirlpool 24 in. DU850SW - Multiple Color Free-standing Dishwasher Logo
167 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
