Question about Kenmore 44102 Front Load Washer
Leaking front loader
I have a kenmore front loader that is leaking water out of the tub I think Im not sure which model it is but itas about 3 years old. What is the matter with it?
  • anniehuffy Feb 25, 2009
    can this rubber boot be replaced
  • 121 Answers
The most likley place is the front rubber boot it can get a small hole in it and leak if the hole is not to large you can clean and dry it and reseal it with silicon rubber sealent
Posted on Dec 03, 2008
I have water leaking on maytag legacy. 9 years old. getting worse over 3 months. removed front and rear panels, dried out and looked for leaks. only water was on agitator base. im thinking tub bearings and...
Look for splatter signs along all of the inter panels, including the ones removed, splatter marks will be just below the line of the tub. Pleazer Appliance...
Apr 14, 2014 | Maytag Legacy Top Load Washer
My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Nov 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My kenmore HD 90 washer model 110 82993800 leaks with a larger load and seemingly only on rinse. Water is on floor and has progressively gotten worse. when I moved the machine there was a dark powder on...
This washing machine is nearly 20 years old. The newer ones save you a lot in using less water per load and you would be better off financially in the long run.
My new front loader saves me $40.00 a month because it is so conservative with water.
Jun 08, 2017 | Washing Machines
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Crack in the bottom of my Kenmore washing machine tub
What is the model number? Is this a front loader or a top loader? To answer your question, yes, the tub can be replaced. You need to take a look at your warranty information to see if this can be replaced at no cost to you. Most manufacturer's warranties cover the first year against any major defects. However, some warranties are extended on certain parts. Something you may consider.
If you post back with your complete model number, I can give you an idea on how much a replacement tub may cost you, and if you have to pursue this on your own...I can give you the steps required to replace the tub.
NOTE: Marine epoxy or plumbers goop may work as a temporary fix in the mean time.
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
My washer is not draining and has slowly filled with water
im not an expert but it might be a leak or somethings backing up or there could be a blockedge in the drain.
Apr 27, 2009 | Kenmore Washing Machines
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 44102 Front Load Washer Logo
178 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
