Question about HP Color LaserJet 2600n Printer
Color calibration not ok
Since the three color catrtridges were empty and replaced the 2600N does not calibrate the colors as it should. When printing e.g. purple, the red and blue dots or letters are not in the same position. Forced calibration does not solve the problem. Any suggestions?
  • DeJudge May 11, 2010
    Please specify wether you replaced toners with HP brand or recycled toners.
  • luv2create May 11, 2010
    Just to clarify, the inks were replaced into the proper positions, correct? i.e. magenta into the magenta spot? This is only a calibration issue correct?
Posted on Nov 29, 2010
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Only black white
Thanks for questioning, pl don't post shot cut questions,your inputs are more valuable for us to give straight away trouble shooting..>Check all cartridges are fully loaded?>Before any body attempted for trouble shoot?>Are you checked for supply status?> Are you performed color calibration?**** Do color calibration (go to menu,system set up,quality,color calibration,calibrate now)Take supply status print out(go to menu,scroll to reports,scroll to supply status, enter in to for print)check all colors are printed are not? If printer take print out from system or print demo page from printer menu.. check print quality...and color calibration..****Remove supplies.. observe while closing the door right side in the supply bank supply contacts engaging or not.(while closing the front door the 'bios voltage contact leavers' engages with the cartridge contacts for passing the voltage in to the cartridge for charging,see the attached snap shot)if these are broken,no contacts or not properly driving by the mechanism, results no print.. check for these contacts...*** alignment disturbed, its major issue users cannot perform this activity..submit in service center for this major issue.
Jan 08, 2012 | HP Color LaserJet 2600n Printer
Color copies not clear
I think its alignment problem.Press menu button>scroll to system setup & enter>scroll to quality & enter>scroll to calibrate & enter> scroll to calibrate now & enter.. wait till calibrate completes..check print quality..If its not rectified better to send it to service center..
Nov 15, 2011 | HP Color LaserJet 2600n Printer
Red prints orange instead , i have a hp color laserjet 2600n
Before processing the elighment, ensure that all cartridges are genuine one. In printer menu >go to 'system setup' enter>"printing quality" enter > "calibrate color"..enter...
after completion of the calibration check the quality of print..
Sep 13, 2011 | HP Color LaserJet 2600n Printer
Is there something I can clean on my HP Laserjet 2600n. I've done the recalibration and things that are built into the menu system. The colors appear faded, especially red. There's an echo-type of...
Using the REPORTS MENU print the "color supplies status". Make sure everything is good.
Select SYSTEM SETUP. Select PRINT QUALITY. Select CALIBRATE COLOR. Select CALIBRATE NOW.
Check the Transfer Belt(ETB) which is inside the front door. Make sure that it is free of your "racing stripes".
You can use HP TOOLBOX to troubleshoot.
You are using HP cartridges???
Dec 12, 2010 | HP Color LaserJet 2600n Printer
I can't print the red color
Check the following steps :
Double-click the HP printer icon in the system tray at the lower right end of your desktop. Navigate to the "Toolbox" tab.
Click on the "Status" link on the left side of the window. Scroll through the "Status" menu and click on the "Print Info Pages" link.
Click the blue "Print" button located to the right of the "Configuration Page" heading. Check the print page to see if the "L" shaped bars are overlapping or bleed into each other.
Contact HP directly for a repair or replacement if the "L" bars do not have any overlap, as that will indicate an extensive mechanical problem that can't be fixed through troubleshooting.
Return to the "Toolbax" tab if the color bars are overlapping. Click on the model number of your HP color laser printer at the upper left end of the window. Click on the "Device Settings" link.
Choose the "Print Quality" option and then click on the "Calibrate" button on the right side of the window. Click "OK" in the new window that appears and wait for the alignment calibration process to finish.
Attempt to print a document again and see if the alignment is still off. If the alignment is not correct, repeat the calibrating, since the HP color laser printer may need to be calibrated more than once to fix the alignment.
Nov 06, 2010 | HP Color LaserJet 2600n Printer
I have a HP Color Lasterjet 2600n when I print in blue, the printer prints a "shadow" of the letters in a pinky color to the side of the blue text.
calibrate the printer three times then close the prionter at least 30 min.restore on factory defaults (cold reset).
Sep 29, 2010 | Office Equipment & Supplies
Color alignment
Clean or repalce sensor belt responsible for the wrong color register.
Oct 22, 2009 | HP Color LaserJet 2600n Printer
HP2600n color printing not registering
Looks like theres a problem with the color ragistration.
I would calibrate the printer. Heres how;
  1. Go to "System Setup" on the display. Press Select.
  2. Go to "Print Quality". Press Select.
  3. Go to "Calibrate Color". Press Select.
  4. Go to "Calibrate Now''. Press Select.
  5. Press Select again to confirm Calibrate Now.
This will calibrate the printer and should eliminate the color registration problem you are having.
Nov 11, 2008 | HP Color LaserJet 2600n Printer
Magenta backgrounding
If the magenta is low the waste bin may be full and that may be causing the problem. If this is the case you need to change the toner. You can try calibrating the printer. You may have to do this 3 times in a row for it to make a difference.
Press Select-check mark button
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Jul 31, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
731 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
