Question about Microsoft MNTR TYRIS|LCD 19' 8MS DVI T901DB Monitor
Screen picture & LED green light keep flashing on and off
My monitor is a tyris 17" TFT LCD display, model # T701DB. Basically the screen just keeps flashing on and off, as well as the green led light. When it's on you can see the picture and the mouse also works on that screen. It'll just flash on for half a second then off for 2-4 seconds. I think it first started after I took my pc out of the screen saver (Shutterfly) that was on, then it just started acting up. Could this be a power cord problem?
  • 558 Answers
No it is a few bad capacitors on the vga board internal thes need tobe replaced or you can return the monitor if it is less than a year old
Posted on Dec 03, 2008
2 Suggested Answers
  • 11 Answers
SOURCE: Tyris Tyris 17" LCD F179 T701DB monitor image appears for 2 secs
Tyris Model: F179
No Power
Purchased an AsIs non-Working Tyris F179 from Goodwill for $15. Opened the case, found no swollen capacitors. Tested the capacitors on the power board and found C203 680uf 16v and C202 680uf 16v only partly working. Could not find a pair of 680uf caps and since they were in paralell on the same traces I removed both of them and substituted with a single 1500uf 16v capacitor. Next, the video board does have a Novatek chip much like the Novatek chip in the Samsung 710n but look closely at the 5 and 6 legs, they are not being used in the Tyris design so the 5/6 50ohm resistor fix is not needed here. Did find C107 , C16, C50 weak, all 47uf 16v, so i replaced them. Reassembled and now have a great picture again.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
For Reference_Novatek Chip goto near bottom of page
http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
Posted on Mar 09, 2009
Screen is blank. Green LED power light is
Might be your graphics card, try swapping it out for a new one and see if that works
Oct 09, 2009 | Dell E173FPb 17" TFT LCD Monitor
What should the tyre pressures be on a vw sharan vr6, 225/45/r17?
Tyre pressure is given by the manufacturers for both ride comfort and wear. For comfort, most are recommending 32 PSI, I personally have found with the lower profile sport tires, that running 35PSI gives the best ride and tyre wear.
Oct 06, 2009 | Microsoft MNTR TYRIS|LCD 17' 8MS DVI...
Vga componet keeps showing up on the screen.
Assuming safely that you have a Dell E173 monitor, i would suggest the following steps to fix this...
1. Press the (+) button on your monitor to make it do an auto-adjust of the display.
2. On the on screen display (OSD) which can be evoked by using the menu button on your monitor - use the +/- key to get the factory reset option high lighted and press on the menu button to execute it.
This should take care of your problem, let me know how it goes!
Jan 12, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Sounds like a bad inverter or CCFT(s). Adjust the brightness to the darkest setting. If the display stays on longer, the you have a bad CCFT(s). If it still goes out the suspect a bad inverter.
Aug 30, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Power ok but No Display
see this one
http://www.fixya.com/support/t155971-benq_t701_lcd_monitor
Sep 16, 2007 | BenQ T701 TFT 17" LCD Monitor
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
Microsoft MNTR TYRIS|LCD 19' 8MS DVI T901DB Monitor Logo
468 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
