Question about Compaq Presario C700T Notebook
''y'' key is hard to press.
I'm not sure what happened. I had my labtop out in one class, put it away, transprted it to the next class, and the 'y' key was just very stiff. It feels like I am pushing down on something besides the key, but i havfe aready cleaned under the key with a q-tip and found nothing. When I press down on it, the bottom left corner of the key seems to be the area where the problem occures, as when i press it, except in that corner, is always presses on a ''slant'' downward toward the opposite corner. It is very annoying, and its hard to write papers when sometimes the 'y' dosen't register because I don't hit it hard enough. Nothing has been spilled on the labtop, in fact its only 4 months old. It's a Compaq Presario C700....any help is much appriciated! (I have not taken the key ''cap'' off because I'm not sure if they come off, if i could just pop off the 'y' cap to fix this please provide instructions for how to do this.)
    Novelist:
  • 89 Answers
There are little plastic rails under the key cap. Many act like scissors under the key cap. it sounds like the corner of the hinge popped out. Even if I could explain how to fix this it is still very difficult. I suggest taking it to a reputable repair shop. It should be a simple fix for them. If you decide to try, just pop off the key cap, but be very careful as the cap can break as well as the parts underneath. If you do get the key cap off and the hinge is disjointed, you can try to put it back into place. You must also be careful of the little rubber pad underneath. If you loose that all hope is lost.
Posted on Dec 06, 2008
Installed new CD drive and computer wants to format hard drive
hey nothings wrong with both ur cd drives try doing this:
Click on the Start button.
If you're using Windows XP, also click on Run.
In the search box (Windows 7 and Windows Vista) or the Run textbox (Windows XP)
type regedit and click OK or press the ENTER key.
This will open the Registry Editor program.
Locate the HKEY_LOCAL_MACHINE folder under Computer/My Computer and
click the '> or (+) icon next to the folder name to expand the folder.
Continue to expand folders until you reach
the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
Click on the '> or (+) icon next to the Class key to expand it.
You should see a long list of subkeys open up under Class that look something like this:
{4D36E965-E325-11CE-BFC1-08002BE10318}
On the rightside column.....delete upper filters and lower filters
restart the computer......that should fix the problem and you can use your old cd drive again......but if it doesnt......visit the nearest tech-centre
Mar 27, 2014 | Compaq Presario CQ60-220US PC Laptop
Can you advise please
reset the machine make this: God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 28, 2013 | Precor 935 Premium Series Treadmill
Acer labtop
Hi Jason,
This message usually indicates that the boot sector is damaged or missing. The boot sector is a region of your hard disk that contains information that is used to load your operating system. If a boot failure is detected when your PC is starting, you may receive this error message.
To resolve this issue, use the steps in the following KB article:
Microsoft Knowledge Base (KB2622803)
Instead of reading everything from the link to Microsoft above, you could try this:
You'll need to repair or copy the bootmgr file.
Do the following steps:
  1. Put the Windows installation disc in the disc drive, and start the computer (In the BIOS settings, make CD/DVD as first bootable device)
  • Press a key when the message indicating 'Press any key to boot from CD or DVD' appears.
  • Select a language, a time, a currency and a keyboard or another input method and then click next.
  • Click Repair your computer.
  • Click the operating system that you want to repair, and then click next.
  • In the System Recovery Options dialog box, click Command Prompt.
  • Type Bootrec /RebuildBcd and then press ENTER.
Let me know how it goes, good luck and if this was helpful please rate me.
Thank you
Apr 27, 2013 | Cell Phones
My labtop carnot start Windows 7 and i have no renovere cd. How kan i start it?
During the boot process you will see on the screen to press a certain key usually delete or the F2b key to enter setup
depending on your which bios you have it will differ
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Mar 30, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
My computer does not recognize the hard drive. Blue light is on. I tried a new USB cable, but nothing happens.
For that you need change some registry keys and delete upper and lower filter with below method. First make sure usb cable connected to harddrive is working fine. Try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Aug 12, 2011 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
My hard disk drive does not respond or show up in My computer when plugged in.Its a seagate 1 tb with those lights in front which usually light up when connected but even that doesnt happen when i plug it...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Oct 06, 2010 | Seagate FreeAgent Pro 1TB External USB...
When connected to projector i could not get the display in not in the labtop and screen
If you have not done so already, hold down the "FN" key next to the spacebar and press the "F5" key. This sill cycle through the display options. Laptop only, External display only and both the laptop and external display.
May 17, 2009 | Toshiba Satellite U300-ST3091 Notebook
Labtop Brightness Problem
plug in a usb keyboard, use the FN key on your laptop keyboard and the curser key on the usb keyboard, problem solved :) you can also use your on-screen keyboard in all programmes, accessories, stystem tools
good luck
Nov 14, 2008 | Computers & Internet
Toshiba laptop A105
Power off the system and wait a few seconds to make sure that hard drive has spun down.
Hold down the "Backspace" key while powering on system.
The following message should appear:
Warning: Can't restore Hibernated State.
Press any key to continue.
After pressing a key on the keyboard, the system will continue with the boot process and the hibernation/standby mode will be by-passed.
a fellow member had posted this
hope this helps
Have a nice day!
tc
Jun 12, 2008 | Toshiba e740 Pocket PC
Compaq Presario C700T Notebook Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
