Question about Boston Acoustics GT-42 Car Audio Amplifier
Safe light on??
Amp was working fine, turned it on played 10 mins and shut off, safe light on. cheked fuses one of the 25-amp fuses was blowen. replaced.. still in safe. any way to reset this or any info on this problem???
    Problem Solver:
  • 22 Answers
Most of the time in my experience when that happens the amp usually has a fried circuit . make sure no wires are touching or grounding out. Also make sure both the 12 volt constant and remote both have power still. And a good, short ground is a vital key to a proper audio system.
Posted on Dec 03, 2008
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
20-Volt DC Power Supply instead of 12-Volt amp
Here's a few things that come to mind. An auto charging system will operate normally from about 11 Volts to about 14.5 Volts, depending on what is operating (lights, blower,etc), and whether the vehicle is at idle or not. Most car amps will operate from about 10.5 to 16.5 Volts, and outside that range, they will probably shut down.
Another consideration is your 20 volt power supply. You didn't mention if it is a DC power supply, but it needs to be. The other factor is its output, meaning its amperage rating. I'm figuring it will need to put about 5 amps, at the least, for the Sony to put out some watts. I think the line fuses of the Sony are rated @ 25 amps each.
I don't like this type of situation, because I want to say 'try it and see what happens" and I want to say 'don't do it, something may blow".
If you decide to try the 20Volt power supply, maybe if you put smaller rated fuses (say 10 amp) in the Sony amp, they will act as a fail safe. Good luck!
Jul 26, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Jl 500/1 amplifier will not turn on
you may have burned the channel you were using..try taking the cover off the amp and checkin for burned spots or any wires that may be loose or touching within the amp.
Feb 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
Safe light boston gt 20 amp
First,check the output functions of your radio.
Then test the power lead for 12+ volts and ground at the amp, also be sure the "turn-on/remote power" lead from the radio is supplying 12+ volts when the radio is turned on.
Good luck...
Feb 22, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
Amp is shutting off after 10 min of driving!! please help!!
Does it happen at all volume levels?
What is the gain setting on the sub amp?
Have you checked for 12V @ remote turn on after problem occurs?
Sounds as if the remote turn on relay inside the amplifier is losing signal, or has become damaged. If the protection light does not light up, the problem is not thermal, shorting, or high/low voltage.
The amplifier is in need of repair. This is not an end-user fix. Looking at about $50 to repair.
Thanks for using FixYa- a FixYa rating is appreciated!!
Feb 18, 2009 | Profile BAJA HA700M Car Audio Amplifier
Moisture in amp while on, caused a small pop, then no sound outpu
check the fuse between the battery and the amp. (not the fuse in the back of the amp).
if that doesn't work then something on the inside of the amp is fried.
Jan 30, 2009 | Phoenix Gold Xenon-200.4 Car Audio...
Sony xm-1002hx
If the fuse blows only after the remote voltage is applied, the output transistors have likely failed. Never use a fuse larger than the one recommended by the manufacturer. It can lead to more extensive damage (including damage to the circuit board) which will make the amp much more expensive to repair.
Sep 23, 2007 | Sony XM-1002HX Car Audio Amplifier
Cant turn up the music witout the amp shuting off
look insayd tz100 is dead replaeis end troae egayn
Mar 29, 2007 | Alpine MRP-M350 Car Audio Amplifier
Boston Acoustics GT-42 Car Audio Amplifier Logo
147 people viewed this question
Top Boston Acoustics Car Audio & Video Experts
xxxxxx xxx
Are you a Boston Acoustics Car Audio and Video Expert? Answer questions, earn points and help others
