Question about Canon Rebel XT / EOS 350D Digital Camera
Error 99 on screen with the 18-55mm lense only
    Scholar:
  • 170 Answers
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
Posted on Sep 02, 2010
2 Suggested Answers
SGNath
  • 170 Answers
SOURCE: I am using a canon
Testimonial: "I did as your recommendation but the problem still persist intermittently. I guess I need to take it to the service centre. Thanks"
I dropped my canon rebel xsi from about 7feet, but it still took pictures after i checked it. nothing cracked, not the lense, or the screen. but than about an hour later, when i tried taking pictures it...
It could be several problems. One is a bad contact between lens and camera body, clean the contacts , check for damage and try another lens if you have one. Try another memory card. Another problem could be with the shutter which would need the camera to be repaired by canon.
Jan 02, 2011 | Cameras
My cannon rebel eos DS6041 displays error 99 when
Jun 01, 2010 | Canon Digital Rebel / EOS-300D Digital...
Using a 70-300mm sigma lense on a canon 350d i error 99 flashes
Error 99 usually refers to a shutter error with the camera. It is most likely not your lens, but you can try it on another body just to be certain. Try PhotoTech Repair Service, in NYC. They are an authorized service facility for Canon cameras. Also if you join they're facebook discount, they will give you 10% off the repair.
Here is the link to the facebook page, it has everything you need to send in your camera.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Apr 02, 2010 | Cameras
My canon EF-S 17-85 IS USM lens will cause an error 99 when in wide angles at 35mm or less. The iris closes but will not open until I "re-boot" the camera. Other lenses work fine on the camera and the...
Zborn, did you find any solutions? I have had same lense for 2-3 years, taken maybe 10000 shots and just yesterday started to get error 99. Spent most of today trouble-shooting to repeat problem and it seems that when I set to less than 35mm I get the error 99. other settings and my other lense has no problems.
Dec 18, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Error 99 on EOS Canon 450D
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Dec 04, 2009 | Canon EOS 450D Digital Camera
Its says error 99? means? can somebody help me? saying shooting not posiblle , needs to turn off/ then turn on.. and i tried so many times but it never helps. please help me .
hi
this error 99 is generally occured when the lense is not recognized
this has been a common problem reported
we'll clear the contacts and connect the lense
try turning the Image Stabilization off and this could solve your problem temporarily
hope this helps
cheers
pls reate the solution if this helped any
Jun 28, 2009 | Tamron 28-200mm F3.8-5.6 for EOS
Get error 99 message
err 99 is moisture or dew inside the camera.
May 07, 2009 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Error 99 in canon 400D
You will get that error when using some lenses other than Canon. A lot of the older Sigma lenses have that issue. Do you get this error when using newer Canon EOS lenses?
Apr 01, 2008 | Canon Digital Rebel / EOS-300D Digital...
Error 99
Assuming that other lenses function normally on the camera, the "Err 99" can be caused by a failure of the aperture component in the lens. Error 99 is a generic error, so unfortunately it does not indicate exactly what is wrong. There are other factors that can cause the failure, but there is a good chance that the aperture is not functioning correctly. You can try cleaning the electrical contacts on the lens, if this does not work you may need to get the lens serviced. Check with Canon, or check the web for other repair service providers. David Millier Advance Camera Repair
Mar 05, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon Rebel XT / EOS 350D Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
