Question about Daewoo DTQ-25S3FC 25" TV
The picture on my Daewoo DTQ-25S3FC is stretched
When i turn on my Tv the picture is majorly stretched. When i let it run for a while it almost goes back to normal but it's still stretched top and bottom. It's like watching a DVD on the zoom in mode. There's no menu to adjust the screen height or anything and i was wondering if there was a hidden menu or if it was something inside the tv that had to be fixed.
Any input would be appreciated.
Thanks
  • lestatsdarka Dec 09, 2008
    >.< i was hoping that it would be a more simple solution....but oh well...thank you for your time and help. (^-^)
  • 121 Answers
Bad electrolytic capacitors vertical circuit. need tech.  not worth repair. guess100.00   not easy repair.
Posted on Dec 04, 2008
Need to program a rca converter box with Daewoo remote control
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 09, 2013 | Televison & Video
Universal remote code for Daewoo Model #DTQ-27S4FC
Check these codes. These are setup codes for Daewoo TV with RCA-RCR311W remote control. 1004, 1011, 1025, 1056, 1078, 1085, 1087, 1103, 1123, 1132, 1205, 1208
Jun 25, 2012 | Daewoo DTQ-25S3FC 25" TV
Remote control for daewoo dtq 25s3fc
Hello
just buy one universal remote control, which have setup codes for Daewoo TV, in its code list.
Codes for daewoo are:
004/ 005/ 009/ 017/ 018/ 019/ 042/ 058/ 082/ 083/ 085/ 097/ 100/ 126/ 127/ 130/ 138
0130 0004 0009 0100 0005 0138 0043 0140 0039
0252 0279 0444 0080 0042 0058
0017 0010 0126 0018 0127 0019
Mar 06, 2012 | Daewoo DTQ-25S3FC 25" TV
Retangle black box
Ve al menu de la tv y checa si esta activada la funcion TEXT si es asi desactivala suerte.
Apr 09, 2008 | Daewoo DTQ-25S3FC 25" TV
Horizontal screen size
will probably have to take to service center. will need to get into service menu and nedd serive diagram.
Mar 10, 2008 | Daewoo DTQ-25S3FC 25" TV
Daewoo gb20hits tv/video combo
Sounds like something inside needs adjusting. There are some potmeters, usually *inside* on a TV, that can adjust where the image is located on the screen. On some computer minitors these are outside to let you adjust for different resolutions. Unfortunately, you will probably have to open the TV to adjust this, and you probably shouldn't do this yourself. Why? Because there are components inside that holds thousands of volts and thay might shock you if you touch them. *Even if the TV is disconnected from the mains!* Don't touch anything metal in there with your fingers or with a metal object! If you do open it and try, look for the small screws that can be turned. They may have a slit for a screwdriver on the end. Adjust only one at a time, and only a little until you find one that changes the property you're after (image height in your case). If the screw changes nothing, try a little more, or turn it back to where it was and try adjusting another one. A trained TV repairman should be able to fix this pretty quickly. If none of the adjusting screws helps the problem, it might be caused by a defective component, and you'll have to know quite a bit about electronics to fix it. And while you're at it; clean out any dust in there (there will probably be a lot!) to help prevent any fires later on.
Sep 04, 2007 | Daewoo DTQ-25S3FC 25" TV
Daewoo tv power on but no picture
Angelo, I've been in electronics more than 20 years and I still use the shake, rattle and roll method of testing. :) From what you've described you probably have a poor solder joint somewhere on the CRT board or in the vertical deflection. Turn it off, unplug it and leave it sit awhile. After a few hours you can remove the back and carefully inspect the CRT board. That's the little board you'll find plugged onto your picture tube. Be careful NOT to touch the printed circuits. But with your glasses on look at the solder connections on each of the components. If something looks like it has a tiny crack all the way around the solder connection remove the board and resolder that connection... if you find nothing there you can remove the main board and do the same in all the area around the IC's that have metal heat sinks attached to them... If you find something that looks suspicious carefully solder it up... With all that you should find the problem and if not button it up and take it to a repair shop. It isn't too expensive to have some poor solder joints repaired.. In our shop here it would be about a $60 dollar job plus tax. Hope this helps Bill
Jun 07, 2007 | Daewoo DTQ-25S3FC 25" TV
Compressed picture in the upper corners of my Daewoo DTQ-20U4SC TV
It sounds like you have a "pin cushion" problem. There is a "pincushion circuit in your set that causes it to make a "square" picture. Some component in this circuit has failed. I am assuming that your set is the "picture tube" type--- not LCD or Plasma. You need to have a tech check it for you. Stargazer
Feb 05, 2007 | Daewoo DTQ-20U4SC 20" TV
Help....all the characters on tv are green
Hi. When TV has one color only, Unplug CRT Socket. if voltages for cathodes within 10% of each other, Problem is with CRT. check green video amp on crt socket, it may be shorted or leaky, if ok have crt checked for short involving the green cathode.
Mar 20, 2006 | Daewoo DTQ-25S3FC 25" TV
Daewoo DTQ-25S3FC 25" TV Logo
264 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
