Question about Kenwood VR615 Receiver
Speakers What would cause my center and sub to stop working all of a sudden.Nothing has being changed and they worked properly before.I have checked all the wires for breaks and shorts and none are evident
  • 245 Answers
SOURCE: No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
Posted on May 23, 2009
0 characters
1 Points
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio & Video Receivers
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
Front speakers won't work simultaneously with the rest of my 5.1 system
This is an either-or situation. As your manual explains, SP-A is one set of speakers and SP-B is another separate set. Your Yamaha receiver should have an SP-A + SP-B setting but given the way your speakers are currently configured it's anybody's guess as to what the result will be.
Dec 15, 2013 | Yamaha Rx-v365 A/V Home Theater Receiver
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio & Video Receivers
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
Centre and subwoofer not working. Checked both speakers by changing wires. Speakers not faulty. ? Maybe a fuse blown. Where do I check the fuses?
Make sure the center and sub are recognized in the receiver's menu as existing. Also, check what playback mode the receiver is in; i.e., a two-channel stereo mode won't send signal to the center, sub, or surrounds, if you have them.
Dec 22, 2010 | Audio & Video Receivers
Yamaha RX-V365 Receiver, Yamaha NS-AP2600S(BL) Speakers
Make sure the speaker select switch is on "A or B or AB. It's a small button on the front panel of the receiver (pen sized) and will give you visual feedback on the LCD display. If they are on, you need to have the unit bench tested at an audio shop and possibly repaired. Hope this helps
Jun 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I've gone through all of the setup procedures, only the front speakers work, nothing from the rears, center, sub or sides. When setting up with the mic, all goes well?????????????? Onkyo TX-SR602. Tried...
I would forget the TV for now. I would use another input source to confirm where the problem is. I would hook up a CD or DVD player to it and check that the speakers are working as they should. If they do work, you may have a bad cable from the TV. Or the new TV is not set for surround sound. It may be as simple as selecting the proper decoder from the TV menu.
Dec 04, 2009 | Onkyo TX-SR605 Receiver
Can get either 1 or 2 speakers working at the same time.
u can't do use a 5 with a cox only with fiberoptic than it will work
Jan 12, 2008 | KLH R5100 Receiver
Kenwood VR615 Receiver Logo
27 people viewed this question
Top Kenwood Audio & Video Receivers Experts
Level 1 Expert
Level 1 Expert
Are you a Kenwood Audio and Video Receiver Expert? Answer questions, earn points and help others
