Question about Lands Phones
Speaker button not working on Uniden WDECT 2315
The speaker button just gives a very loud volume tone............it used to work fine.........
Didn't get any response and the instruction book doesn't address this problem in the trouble-shooting pages..........so I swapped phones with someone who doesn't need to use the speaker.
Posted on Dec 04, 2008
Uniden bcd396xt scanning but no sound coming from scanner
BCD386XT No sound. If it is actually stopping on an active broadcast and if you have the volume turned up (press down on volume button and release, then rotate to adjust) then the most likely cause is a failed speaker. Try a set of headphones in the jack on top by the antenna, if you have sound there it is most certainly a bad speaker. It is a very tiny speaker that is as thin as a nickel, many have been broken by a simple jar or by being played too loud by the hearing impaired. It is not hard to change but basic soldering skills are required. the speaker is available from uniden parts.
Apr 05, 2013 | Uniden BCD396XT Handheld Scanner
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My uniden tect1580 doesn't ring
First thing to try is while the phone is in "On-Hook" mode, press the up key on the handset several times, you should hear a beep each time you press the button and the display should show "Ringer Volume" with a graduating series of bars. If the display shows as above, but you do not hear any rings, try pressing the "Speaker" button and listen for the dial tone. Most of the time on these phones, it is a simple matter of turning up the ringer volume, but sometimes, the handsfree speaker (Which also acts as the ringer speaker) goes bad. If the speaker is bad, it is a fairly easy replacement if you are handy with a soldering iron.
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
Wdect 2315+1
Check if the screw of the phone is not too tight, because the button might press by itself if it is too tight.
If the problem is not solved,what I do in a situation like this is to loose the phone and use cotton wool or soft brush to clean it with a little mentholated spirit, leave it in the sun to dry, after drying, allow it to cool a bit and couple it back.
You should not clean the screen with spirit, you should clean only the board and the keypad also. Just a little spirit and don't let it be too much. You can dry in any other heat apart from sun and don't allow it over heat.
I wish you the best.
Nov 06, 2009 | Uniden Cordless Phone
LG Prada Loud Speaker & Exculating Ring Tone
press the lock key on the side during a call to activate the speaker phone option and then press the required touch button on the screen.
Piyush
Jun 10, 2008 | LG Prada KE850 Cellular Phone
Sony str-de875 amp. one speaker louder than the rest
hi. i have a sony amplifier. i plug the speakers in like normal. i turn it on and the right side speeker works fine. but you half to crank it up all the way just to barely hear the left speeker. we switched speakers and its still the same effect. we think its the amp itself. we tried our balance settings. it was fine. but right now its just playing one speaker louder then the left one. can anyone help me?
Apr 03, 2008 | Sony STR-DE875 Receiver
Handset doesnt work
Do you have another phone (cell phone) you can use to make a test call to yourself? If you can answer a call and the Uniden transmits voice OK, then it is probably the speaker and may just be a bad solder connection. If the handset does not transmit or receive I seriously doubt you have a bad microphone AND a bad speaker, you'd be looking at something more serious.
Jul 25, 2007 | Uniden EXS 2080 Cordless Phone (EXS2080)
Lands Phones Logo
81 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
