Question about Sony PlayStation 2 (PS2) Console
Ps2 connection problem
My ps2 is properly connected to my tv's av input, but it isn't being recognized. what could be the problem?
  • 4 Answers
It could be that you have the incorrect input selected on the tv. Try hitting the input or tv/vcr button several times on the tv.
Posted on Dec 03, 2008
Playstation 2. All the cables etc, are connected and tight, to their respective locations. I just do not know what channel on the TV, that permits game use. I am a pensioner, and unable to find the...
It isn't a channel, you will need to switch the video mode from cable TV to auxiliary inputs (i.e. VCR, DVD player, games, etc). The process for doing this varies from TV to TV but generally the remote will have a button that says 'Input' or 'Video' and that will switch it.
May 30, 2011 | Sony PlayStation 2 (PS2) Console
How do I connect my PS2 to my Alba flatscreen TV? I plugged it in and everything but I go through all the channels and AVs (HDMI, HDMI2, Ex-1 ect) but I can't seem to find the channel that the PS2 has...
select the channel that corresponds with the way you connected it if it is component video check those inputs otherwise it could be an hdmi input. if you have it hooked up and you know for sure you have checked the input that corresponds than you most likely have a bad cable try a different cable to hook it up
May 09, 2011 | Video Game Consoles & Games
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a ps3 60gb capatible for the ps2 I have it hooked up to the TV but its not showing anything on the TV I have the High Def connectors for the TV
It is a known problem with some high def connectors not working properly. The following should be checked before concluding there is a problem
1. Ensure you have your TV tuned to the right output station for as your ps3 is connected.(for example you cannot have your ps3 connected to the second set of av ports on your tv and your tv is on av1, it has to be on av2)
2. Cross-check the functionality of your ps3 using the default av cables that come with it so as to know if your cable or console is faulty.
3. Ensure that you high-def cables are properly connected.
If all the above prove abortive, you have to see a repairer to check-up your ps3 or tv
Dec 25, 2010 | Sony PlayStation® 3 (60 GB) Console
Weve got a toshiba tv model 289s4A & want to plug our ps2 into it, cant find how go get the av channel on the tv. We have connected the av cables but when you change channels on the tv, theres no...
If you have the remote, look for the source button. It should allow you to toggle the settings.
Otherwise they are usually after channel 2 as in Hdmi, Av1, AV2 etc..
Good luck
Dec 09, 2010 | Toshiba Televison & Video
How do i hook it up to my ps2?
Your Ps2 should have a connecting lead that terminates in either a SCART plug or a set of 3 phono (RCA) plugs. The TV will have SCART inputs, and also will have Phono (RCA) inputs. So you connect to whichever is applicable and then turn the TV to the correct input. Usually this is done by using a button marked 'AV' or 'Input'
Jul 27, 2010 | Televison & Video
Cannot get 27" jvc av-27530 tv to recognize playstation 2
Do you have the remote? You will need to cycle through the inputs to get to video 1 or 3. You might have the buttons on the front of your tv that says tv/video or tv/vcr. If not go down the channels past 1 and it might automatically switch through the video input selections. For any of these solutions have the PS2 plugged into video 1 and turned on. Hope this helps.
Jan 04, 2009 | JVC AV-27530 27" TV
Vdo does'nt play
Sometimes your TV might might have the problem, check your TV.
Did you connect the AV cables properly, check if it is connected properly.
if problem still persist, please check your TV AV components
Jul 30, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 hookup to lcd tv
If your sanyo has a video input (yellow) available, and audio inputs available (white and red) then you just need to connect them. Then you need to select the proper input on the TV set. These may be on the back, side, or front of the TV.
Good Luck, and let me know how it worked out!
Jan 01, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
79 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
