Question about Bose 3·2·1 II System
Sound cuts out on Bose 321 System
At high volumes the sound will cut out
  • Transit Cop Jan 04, 2009
    Hello all, my BOSE AV3-2-1 Series II system does the same freaking thing. At higher volumes while watching DVD's when things such as explosions, car chases, screaming or yelling happens the entire system cuts out for a second and then comes right back.
    Is this somethig I can fix, I have even turned my bass way down to like # 4 and it still does it. I am good with the volum level unit I hit about 68 to 70, themn it cuts out.
    please help me.....
  • KODIBEAU Mar 29, 2009
    my problem is identical - sound cuts out with gun shots, crashes etc over 68....HELP
5 Suggested Answers
  • 45 Answers
SOURCE: Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
Posted on May 08, 2009
  • 156 Answers
SOURCE: my child messed with the settings on my 321 bose
Reset all EQ settings to 0 for a starter. It sounds as if it is EQ'd down all the way.
Posted on Jul 06, 2009
  • 10 Answers
SOURCE: bose 321 system stuck at 30 volume
Is vol buttons button on unit do the same, try remote.
If not try unplug from wall wait hour and try agian, if not bose update cd..
Posted on Aug 20, 2009
SOURCE: the sound suddenly cut out for my Bose 321 GSX system
I now have this same problem. Would like to know if there is a fix or if my system is just failing for good
Posted on Feb 17, 2011
Bose 321 series II giving very dull sound in all inputs. Occaisionally the sound cuts and comes back with full and bright trebble, but then cuts back to original dull sound. I cant see anything the ad
Try the following:
1) Switch the unit off completely, using the powerswitch on the back of the bass box.
2) Switch the unit back on via de switch on the bass box.
3) The display should read BOSE 321 and than be dark.
4) Insert a CD and switch the unit on with the remote by selecting the CD/DVD mode.
5) When the sound is now OK, it means that you need to contact Bose to ask them for the latest software update for your unit. After updating your system. The problem will not reoccur.
6) in case the problem continues and at start-up using a CD, no improvement of sound is heard, the system should go into repair. Contact Bose in your country and ask for return instructions.
Jan 13, 2014 | Bose 321GS Series II System
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
Bose 312 Sound Cuts in and out
Most amplifiers design to cut out when there is an overload, such as playing the music too loud. It helps protect the device from being damaged. If the device does it at low volume, and does it sometimes, check the wring to the speaker, something might be shorting it out intermitently.
Nov 28, 2009 | Bose (321GS) System
My bose 321 is recieving audio from my cable box. the sound occasionally cuts out for a second or two. any sugestions
Thats what they do B4 thay die, try useing a differemt input other then the cable box to make sure its not that
Nov 27, 2009 | Bose Cinemate Digital Home Theater System...
My child messed with the settings on my 321 bose
Jul 05, 2009 | Bose 321GS Series II System
Popping noise and cutting volume on Iphone
i have the same problem. I started after an iphone software update.
Jun 15, 2009 | Apple Bose SoundDock Series II Digital...
May 07, 2009 | Bose 3 2 1 GSX System
The sound suddenly cut out for my Bose 321 GSX system
Apr 09, 2009 | Bose 3 2 1 GSX System
VOLUME ISSUE
I had my older bose 321 hooked up through vcr and sounded great. Then hooked it up through directv receiver and sounded better. then switched from direct to comcast and hooked the bose up throught the comcast hd receiver and the volume is aweful. same deal, have to crank it up high. Since the stereo built into the tv sounds so much better I disconnected the bose and am going to sell it.
Dec 28, 2007 | Bose 3 2 1 GSX System
Bose 3·2·1 II System Logo
374 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
