Question about Sanyo DP42746 42 in. Plasma Television
I need a manual for Sanyo 42" HDMI TV
ANY SUGGESTIONS PLEASE?
    President:
  • 2,110 Answers
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
I connected my Mid 2009 Macbook Pro to my Sanyo DP42746 Sanyo with a minidisplay port to HDMI adaptor. My Macbook doesn't support sound through the minidisplay port. The TV owner's manual suggests...
It may have something to do with the settings under audio output devices. See if you have options, and ensure that the headphone jack (I assume that's what you're using) is set as the default sound device.
Oct 24, 2013 | Sanyo DP42746 42 in. Plasma Television
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
Computer has vga port and tv has hdmi port
Please know that VGA is an analog signal and HDMI is digital so it is impossible to go from one to the other without a converter. If you need to convert any VGA or component signal into a digital high definition HDMI signal up to 720p resolution, this conversion box will do the job perfectly. The only additional thing that you need to get besides this converter is an HDMI cable of the appropriate length.http://sewelldirect.com/Component-VGA-to-HDMI-Scaler-720p.asp Hope this Helps you!
Jun 16, 2012 | Sanyo 42 in. LCD TV
I cannot get regular tv to come in and my antenna is hooked up properly
Here is a few suggestions:
1) Make sure the tv's vide mode is in "TV" or "ANT" or "Antenna" some times even referred as "Off Air"
2) In the TV's settings make sure a "Channel Scan" has been performed to tell the TV which channels are available in your area. If this is not done you won't be able to select any channels. Also make sure that the antenna is of the right impedance (i.e. 52ohms) check your manual and see what your TV accepts.
3) Make sure that you are using coxial cable connection and not RCA or HDMI connections as these connections are not designed for an over the air antenna.
Mar 02, 2011 | Sanyo 42 in. LCD TV
What kind of HDMI cord do I need to purchase for this TV, I am running DISH Network also. Thanks!
There is only one type of HDMI cable, so any HDMI cable should be fine. Component cables are an alternative to HDMI cables, but keep in mind that component cables do not carry audio, so you will need to have the audio connected separately. Our HD receivers work great with HDMI or component cables.
Phillip Chang
DISH Network Customer Service Representative
Feb 08, 2011 | Sanyo 42 in. LCD TV
Is it possible to connect hdmi cable to sanyo vizon plasma tv
yes it is possible there is one HDMI input on the back of the television
Dec 11, 2010 | Sanyo DP42746 42 in. Plasma Television
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
42" Sanyo HDTV with 3 HDMI Inputs
Everybody is having problems with sony products and HDMI cables. It's on a lot of forums. So, your not alone.
Most of the solutions are:
1. Unplug your TV for 30 mins.
2. Plug TV back in and put it on HDMI for PS3.
3. Hold down the power button for 10secs on the PS3
That should solve the problem.
Feb 17, 2009 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
133 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
