Question about Texas Instruments TI-Nspire Graphic Calculator
Calculator keeps powering off after a few seconds
I just replaced the batteries but now when i try to turn it on it starts to power up and then stops.
  • Anonymous Jan 28, 2009
    same her 0_0
    contaccted ti support.
  • 4 Answers
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Hold down [Home] [Enter] [P], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
    1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
    Note: TI-Nspire family model options 2 and 4 above require that the OS be reinstalled. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
Posted on Jan 30, 2009
15hp Koehler, new battery, solenoid, starter, coil. While trying to start the fly wheel turns approx 1/4 turn then stops with some clicking. When I help rotate flywheel and try again it will start.
New batteries often need to be recharged before being installed. If it does it when battery is fully charged then your statter needs replaced.
Oct 19, 2017 | Cars & Trucks
A ford territory 2006 that won't start, even after replacing battery?
check for battery voltage at the large terminal on the starter. THere should be power at all times.
Have a helper turn the key to the crank position while you check for power on the smaller wire at the starter. There should be power anytime the key is in the crank position.
If there is power at both terminals than the starter is bad. If there is no power at the large wire check your battery connection. If there is no power at the the small wire you will need to trace it back to its origin.
Oct 08, 2016 | 2006 Ford Territory 4.0
Would a dead battery stop your key from turning on in a 2003 gmc envoy
Sounds like a flat battery. Just enough to power your lights but not enough to power the starter motor. Try recharging the battery.and check battery connections are good.
Feb 22, 2015 | 2003 GMC Envoy
I think the starter in my 1997 chevy blazer is bad. when i try to turn it over it tries to start for just a second, but then stops and begins to click. i used to have a problem with my battery posts...
Try removing the battery cables and boost the vehicle with another. If it starts, replace the battery. If it doesn't start check for any loose connections at starter and for power at starter. If you have power, remove starter and have it checked and replace if necessary.
Sep 08, 2010 | 1997 Chevrolet Blazer
Turn signals stopped working now no power
I concur this is a power supply fault of some sort, insure your battery connections are maintained, meaning clean and good of contact, obtain a voltmeter and test the voltage at the battery contacts it should be about 12.5 or higher, turn the key on and try to start, noting the voltage, if it drops below 11 volts, there's your fault if not a poor ground from the battery and the frame of your vehicle may be faulty but boosting your vehicle from another sports battery fault
May 05, 2010 | 1998 Plymouth Voyager
Acer Aspire 5720 Laptop issues.
It could be the battery. So i'd try to find a store that sells batteries and replace the battery.
Manny laptops will shut off when the battery is dead. So if your laptop works without the battery and only connected to the wallsocket, it's definitely the battery.
With kind regards,
Jeffrey
Feb 16, 2010 | Acer Aspire 5720-4984 Notebook
Screen only turns on randomly during start up, led lights are lit, laptop sounds like it wants to turn on and stops, then tries again, then stops. Problem happens about 9 out of 10 start ups, and when it...
remove battery, press and hold power button for 5 seconds, then wait 5 minutes, put battery back in securely and try again. If it powers on, try and look at the power meter to see if it is registering the power supply. You could have faulty memory chip or faulty power supply
Nov 30, 2009 | HP Pavilion dv6000z Notebook
When I turn it on it doesn't start out in the circle motion but starts and than stops and than starts and than stops and moves erratically and than totally stops.
Try a different battery. If no go, you might have bad board or sensors. Basically, if the battery replacement doesn't fix it, get rid of it. Borrow a battery from someone else so you're not wasting your money for testing.
-=/ Daft Tech /=-
Oct 25, 2009 | iRobot 5800 Scooba Vacuum
Car started fine..stopped, no restart, no click, dead lights on.
try getting a boost for your car.... the battery may be failing. it doesn't take alot of power to turn on the lights... but a huge drain on the battery to start it. if it will not start with a boost i could very well be that the starter has failed. as you attempt to start it... have someone tap the starter with a hammer. if it starts... replace the starter.... if it starts normally with a boost you likely need a new battery
Mar 26, 2009 | 1988 Volvo 240
Texas Instruments TI-Nspire Graphic Calculator Logo
545 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
