Question about Dishwashers
I have a Kenmore Elite dishwasher, model number: 665.17263. The clean green light is blinking and unit work work. I had this problem before and the service guy showed me how to press the buttons in a certain sequence which fixed the problem. It was the heating element.
  • lpgilman1 Dec 07, 2008
    I did rate the service.....
All I had to do was to press the heatdry and normal wash buttons until all the lights went on. This happened before...Gingko was fantastic!!
Posted on Dec 04, 2008
Blinking clean light, not completing cycles
some of the dishwasher have a device in them that you have to remove the container and clean it. mine is up side down cup that unscrews.
go to www.wikipedia.org
kenmore elite blink clean light
or go on to www.sears.com/service
talk to someone or look on line at
www.youtube.com/kenmore_elite_blinking_clean_light
see if anyone else had this issue
Mar 25, 2015 | Kenmore 24 in. Elite Built-In Dishwasher...
Dishwasher wont finish any cycles
That blinking light is trying to tell you that there is something wrong with the dishwasher. You need to fix the problem or else that blinking light will come back. And the number of times it blinks (before it pauses and repeats) will tell you (or a technician) what is wrong. How many times does it blink?
Jul 04, 2014 | Kenmore Dishwashers
Our Kenmore Elite Dishwasher has a blinking green light next to the clean cycle. It won't reset. We changed the motor and this has been going on ever since. Do you know what we need to do to fix it....
Hello
Blinking green light can be reset by following two buttons in sequence: press HIGH TEMP WASH-HEATED DRY buttons in sequence around 3-4 times so that the control reset itself. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
My kenmore elite ultrawash dishwasher, model # 665.16289402, will not start. The green clean light keeps blinking and when you go to push start after selecting which wash program it does nothing.
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
I have a Kenmore Elite, model number 665.17263. The clean button green light is flashing. This happened once before and it was the heating element. The service guy showed me how to put a series of presses...
Push the Heated Dry then the SaniWash buttons. Do this three repeatedly until the whole panel lights up and then close the door. You should be good to go!
Dec 03, 2008 | Dishwashers
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Dishwashers Logo
137 people viewed this question
Top Dishwashers Experts
