Question about Acer Aspire 5315 Notebook
Ram upgrade hi im just wondering if my acer 5315 will handle 3gb of ram as i have read up on the net that it will only take 2gb but others saying 3gb and people with same laptop with 3gb ram and a cpu upgrade can any1 please help
  • aarontonge22 Dec 03, 2008
    thanks for the info but i have a 2gb in one slot and works fine?
  • 104 Answers
Your system support only 2Gb, only 1Gb at one bank. Please Checkout http://www.memoryx.net/aspire53151.html
you can even have your system Scan "Scan My System" from this site to give you an accurate system details.
Hope this fix your problem!
Posted on Dec 03, 2008
  • Vanbiak Thanga
    Vanbiak Thanga Dec 05, 2008
    If you in crease beyond the specified capacity I'm afraid your NorthBridge Chips will bear the cost soon or later since the BUS speed is limited
    Best regards
Ram Installation more than 3G ex: (4G or 5G) will read 3.25 G How? i am using 2 units of KVR800D2N6/2G pulse 1G original>
Probably your Operating System is a 32bit. 32bit OS can only read up to 3GB of RAM regardless of the capacity of RAM you install. For example you installed 2pcs of 2GB RAM, that makes it 4GB in total, 32bit OS will only recognize 3GB. upgrade your OS to a 64bit OS and you can upgrade your RAM up to 8GB depending on how much your motherboard can handle.
Sep 15, 2010 | Computers & Internet
I would like to add memory to my acer 5315 notebook. I have taken the panel off the back, but I don't know where to put the new RAM in. I can only find how to replace memory, not to add more.
The ram location is right where you are looking. There are two memory slots available for ram. They are staggered one on top of the other. Release the side pins and the module will pop up at a 45 degree angle . Pull the module out in the direction and replace at that angle, then push the module down in place. You may only have one memory slot filled at this time, Therefore there would be an empty slot to fill.
Jun 01, 2010 | Acer Aspire 5315 Notebook
Can the Acer Aspire 5102 WLMi handle more than 2GB of RAM? The specifications say up to 2GB.
It handles up to 2 x 2GB soDIMM modules. However, available memory will vary with operating systems; Windows 32bit supports 2GB max. for Applications out of the box and can be tweaked to 3GB.
You'll need a 64bit operating system to use more of the installed memory.
Feb 07, 2010 | Acer Aspire 5100 Notebook
Can an acer aspire 5315 2077 support at least 3gb
The maximum memory that the laptop will support is 2GB, 1x1GB in each slot.
The memory type is DDR2 533MHz.
Regards.
Nov 24, 2009 | Acer Aspire 5315 Notebook
I have an Acer am5100-u5301a. Is there a bios upgrade?
If the specs read that you can operate with 4GB of RAM, then I believe the AMD690g chipset is not the culprit.
The RAM that you're adding may be defective, or incompatible with the existing RAM.
Another possibility could be a bad RAM socket.
I also doubt you would get a black screen due to adding more RAM than the system is capable of handling, it would still start, but would not utilize the additional RAM.
Black screen usually means bad RAM or incompatible RAM or bad socket
Nov 02, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
Upgrade to 3GB in laptop?
yes you can install 1GB in one slot and 2GB in other slot. but you have to make sure that the RAMs must have the same BUS speed.
Please make rating to my answer
Sep 05, 2009 | Gigabyte GA-8PE667 Ultra Motherboard
Hi i have an acer aspire 5315-2326 laptop and i want to upgrade the ram from 1gb to 2gb. what kind do i get? do i replace or add 1 more gb? and what kind of ram do i use? thanks
I would advice you to add one gb more with same value, kind and frequency this you can read on the installed module after removing it from your laptop
Aug 20, 2009 | Acer Aspire 5315 Notebook
Upgrading memory to 4GB failure
try to see if that memory is supported with your motherboard. The memory has something to do with that problem.
Jun 16, 2009 | Acer Extensa 5620 Notebook PC
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Acer Aspire 5315 Notebook Logo
238 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
