Question about Samsung SyncMaster 750S 17" CRT Monitor
Monitor shuts down and glows pink
My monitor shuts down and glows pink after powering up the system, and it will remain that way for a couple of hours, at which time it will come on by itsself. It sounds close to the other problems of shutting down only if it is dark you can see the pink glow. Could this be a driver problem?
  • Terry McD Feb 26, 2007
    Coach Tim,
    Slapping the monitor does not help, (maybe a good kick?) ;).
    I will try another monitor and see what happens.
    Will keep you posted.
    Novelist:
    Champion:
  • 202 Answers
You could try updating the drivers for your monitor and for you video card. It sounds like their could be a hardware problem. When something warms/heats up the connection is made. A pink glow isn't a good thing. Make sure you check all cables and even try to adjust the actual monitor settings Your heat settings for the colors may be out of whack. Last question? Does slapping it a little help? Good Luck. Let me know what happens. Tim
Posted on Feb 21, 2007
    Novelist:
  • 107 Answers
It is unlikely that a driver issue could cause this problem. The pink glow you see is simply the display being powered on but not putting out any signal. I assume, since you did not mention it, that there is no "No Signal" message up on the screen. If there is, or you can see the onscreen displays when you attempt to use the menu system then your problem lies in the computer, or between the computer and the monitor. As the previous solution states, check your cables. Watch the monitor as you wiggle the cable - if the image flickers then you have a bad connection or a bad cable. If nothing changes try a different monitor (if you can) and see if that one displays the image. If that second monitor does not display the image then your problem lies within the computer. David Millier Advance Camera Repair
Posted on Feb 26, 2007
Why is my Lenovo desktop putting out a pink color across the monitor.
Usually it's a problem related to the Graphic card (expensive) but before replacing it I would try the monitor cable on a different Pc: sometimes it's just a matter of a damaged VGA or Hdmi cable, which is cheap to change
death">Pink Screen Of Death
Feb 10, 2015 | Lenovo IdeaCentre K300 (53161BU) PC...
Will not boot up. power button light on
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Mar 31, 2012 | Computers & Internet
I just bought a new motherboard for my soyo MT-NI-DYLM2286 computer monitor and after I installed it I turned it on and got a white/pink screen for about 1sec then it shut off and the power light started...
The backlights lamps should stay on even if the LCD panel section is bad. It sounds like you have to check the power supply voltages, caps, inverter circuits. Bad lamps can glow pink instead of white glow.
Please read my guides to uderstand how LCD monitors work.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | Soyo DYLM2286 Monitor
I hit the button to turn it on it will stay on for awhile and then it will start beeping really loudly an shut off
With your UPS turned off, unplug your PC and all other devices from the unit. Then turn the UPS on. If it still beeps and shuts off your UPS internal battery may need to be replaced or you have an internal UPS failure. Look for a red "battery alarm" light on the front of your UPS.
If the UPS does not shut down with all devices disconnected from it, Power off your monitor and look on the back of the monitor for a label which will tell you the amount of power it requires (probably 100 watts or less). Plug the monitor's AC power cord into your UPS and turn on your PC and monitor. With the UPS plugged into the AC line you are not using the internal battery and the UPS should remain on and your monitor should be working. If it shuts down you have an internal problem with the UPS.
Now unplug your UPS from the AC line (simulating a power failure) Your UPS is rated at 350 watts. Accordingly it should easily support the 100 watt load of your monitor. If the UPS continues to provide power to the monitor for 1 or 2 minutes down it's an indication that it's working properly and the COMBINED LOAD of your monitor. PC etc. when plugged into the UPS is exceeding the 350 watt capacity of the UPS. You will have to disconnect 1 or more devices from the UPS.
NOTE: Never plug a laser printer into an UPS.
If the UPS immeadiately shuts down after disconnecting it from the AC line with only the monitor plugged into it you have a bad battery.
If you found this information to be helpful to you please return to the FixYa website and rate me.
Regards,
Yavacotech
Dec 07, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
No image -- monitor remains black
Without any instruments to check it with, substitution is the best test; in other words connect the monitor to another system for a minute or two and/or a different monitor to your system. (If you can do either, don't do 'hot' swaps, turn everything off and then back on again.)
If you've noticed it; you may have seen that the LED flashes if the monitor is left on and the system shut down. Removing the VGA cable from the back of your system (or the monitor if it is separable) should produce the same result; flashing LED. If this is the case, then your video source from the system (on-board of add-on) has failed. If the video chipset on the motherboard has failed, it can be disabled and replaced by an add-in board for a few dollars.
Oct 12, 2009 | Acer AL1916ASD (Silver) Monitor
Pink line down the middle of the screen
Lcb is liquid crystal display and there is liquid and some chemical in it and it cause this problem .or some put some think on it or you drop the lcd . i also have the same issue . If it is under warrenty replace it.
Sep 29, 2009 | Samsung SyncMaster T240 Monitor
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
LCD display turns pink then goes off
You may be blaming the wrong device. I suggest you try the monitor with another system, the problem you describe could be located in the video output of your system instead of a monitor fault.
Feb 28, 2009 | Samsung SyncMaster 920WM LCD Monitor
Shutting off
It may not be related to room temp, but it sure sounds like there is an internal problem relating to temp. Meaning, there is a component (probably a capacitor) getting over heated or leaking. If this is still covered under the mfg warranty, I would contact them to get it fixed. If not, then taking it to a repair facility that can repair it is probably a good idea.
Aug 17, 2007 | Acer AL2017 20" LCD Monitor
Samsung SyncMaster 750S 17" CRT Monitor Logo
100 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
