Question about Sony Playstation 3 (PS3) Console
PS3 System will not read any disc, DVD.
The system turns on and the contoller works. I ahve tried the long 3.5 hours of updates and that did not work. I tried the update on line and that did not work. What else can I do?
  • dillonjames9 Dec 03, 2008
    My ps3 it wont read the disk at all.
Can u give the code for play station 3 console so i can play the any dvd i just wanted to registered on my divx
player
Mrs R. Ham
Posted on Dec 03, 2008
Ps3 freezing and disc wont read and skips
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
Take care.
I wish you good luck
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
Ps3 seems to stop reading disks was working fine then just stopped i cannot hear any noise when inserting a disk and nothing comes up.
You can also try the steps below. Its from PlayStation Forum:
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with our finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
I wish you good luck.
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
My ps3 stop playing my game disc
The most common reason for the game not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
well as cookies.
Take care.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Do not read the disc
The problem is that the lens of your ps3 is either dirty or weak that it can no longer read any disc, i advice that you get a lens cleaner to clean the lens of your game, if after cleaning, problem persist, replace the lens on your ps3 so that your ps3 can continue to function as it use to function before.
Replace the lens on your ps3 and you will see that it will start reading discs.
You can also try the below procedure,
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 21, 2010 | Sony Playstation 3 (PS3) Console
PS3 - Game crash followed by disc read error
The update corrupted your hard drive that's why it's not loading any disc.Yes,Restoring the system will work but it will destroy all your saved game data.Updating the system will not remove the hard disk defect.There is only one solution,Reset it.
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
Wont read the disc .my sony playstation 3 wont read any disc.
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
Will not read the dvd or games? Doesn't sound like it is even trying to read the disk. I have tried multiple games and dvd's but no luck. Any ideas?
Apr 05, 2010 | Sony Playstation 3 (PS3) Console
It turns on but will no longer read discs.
well as cookies.
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
Disk not reading
I had a similar problem. My PS3 was not starting the game discs when I inserted those to PS3. Also those game discs were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
Select option "Rebuild Database".
After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
MY PS3 DOSENT READ MY GAMES
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Dec 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
