Rainbow vertical lines
I have a wd 52631 mitsubishi projection tv and i have rainbow colorful lines through the display.
  • 15 more comments
  • marktre
    marktre Dec 03, 2008
    mine are all vertical, used to do it when first turned on now all the time.
  • marktre
    marktre Dec 04, 2008
    Tried that. everything works , just has vertical line.
  • marktre
    I guess the picture is pixilated and lines every 2 inches and in between there are ghost lines?
  • marktre
    Hate to sound stupid but the vertical ic is in the light engine right?
  • marktre
    Tried all resets
  • marktre
    marktre Dec 05, 2008
    Do you know the ref# for vertical ic?
  • marktre
    I've looked through the service manuel and read the diagrams and can't find a 100uh 35volt there anywhere. this is a wd 52631 mitsubishi, not sure about the yolk either? maybe if you could tell me if it's on the pwb- e2p or light engine. I would have a better idea where to look, Never fixed a tv but soldering is not a problem. testing for values is also doable.
  • marktre
    In north dakota everything costs alot
  • marktre
    I do have a masters in industrial electronics.
  • marktre
    What i need to know is which board to start checking, so far i have checked 2 pwb's. Just need to know where the vertical ic is located.
  • marktre
    I guess vertical to me is up and down, I posted the photo of the tv.
  • marktre
    Color wheel is turning
  • marktre
    added pic to my profile
  • marktre
    I will give it a try
  • marktre
    and
  • marktre
    I have a scematics and looked at all that it shows, so far I have checked pwb power and pwb signal Pwb-dm is next. If you are talking about the light engine pls tell me. I have the back off and 2 boards checked. stk 393-110 doesn't seem to be listed. From the service manuel, pls tell me the ref# for the parts to be checked, Which boards or light engine. thanks
  • marktre
    Thats what i was hoping not to be,,thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
A problem with the single chip projection system is the ‘rainbow effect’. This occurs most visibly when bright white objects appear on dark backgrounds. When the observer’s eye passes across the image, the viewer perceives a rainbow distribution of colours. This occurs mainly due to the field sequential colour display technique and is not exhibited by three chip projectors. It is considered that the origins of the rainbow effect are to do with the concept of flicker fusion threshold.
Posted on Dec 05, 2008
    Genius:
  • 1,239 Answers
Hi OK, friend.. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms.SOme time SSB is defective ( small signal board, replaced it ) If you have questions?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Could you take in digital image of the display? If possibly yes, can you pls post it here? The image though has to be 150K or less.
Hate to be the devil's advocate but some general ideas in some other models:
  • to a tech vertical line problem would be left to right not up/down;
  • if it were the vertical capacitor, then it would be foldover on top;
  • if it were the vertical IC, then most unit would go to protective mode;
  • if it were the yoke and if you have three tubes, then there should be 3 yokes;
  • retrace lines (Screen problem) are also described as vertical lines albeit fine, white.
  • might it be that there is no vertical IC in the sense
To your specific model, I was made to understand that it uses a digital 1080p light engine and a six-color wheel. Perhaps you can start verifying if the colorwheel turns. If not, then voltage measurement based on the schematic.
Pls post the display image. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 05, 2008
    ahh, now we both have problems.
    1. am not sure if you will be able to view my subsequent posts;
    2. your posted image of the problem indicates:
    • probable loose DVI connector from the main chassis to the light engine. Try to re-seat/reconnect and ensure positive contacts; or
    • possibly faulty optical/light engine. Not sure re Part number, might be something like 938P015020.
    Good luck to both of us.
  • 1,800 Answers
Hi.
when an IC get an over voltage that shud happend.
detecting the faulty IC is not an easy task also replacing it u may make more damage on tv
u can try our repairman service
    Genius:
  • 2,920 Answers
Take the tv to a shop and ask the to replace the vertical ic and re converge the tv. it shouldnt cost alot depending on where you take it to but you have a bad vertical ic and the tv will have to be reconverged when this is replaced
    Novelist:
  • 157 Answers
Some things that can cause this problem
the B+ voltage to the Vertical IC can be dropping
due to a bad capacitor usually 100uf/35vdc
The pump capacitor is failing also usually 100uf/35vdc
this is also on the Vertical IC
Possible by unlikely the Vertical Drive IC can be getting
a diminished drive signal however this is far more common in a Toshiba
The Vertical IC may be failing as it warms up also not very likely it would be a rare failure the IC usually is good or bad
Lastly there was a problem common in Mitsubishi Projos
about the time yours was made
Silicon adhesive was used to hold a mod to the PCB
over time it eat thru the foil to pin 6 of the Vertical IC
perhaps that applies to your situation
Posted on Dec 04, 2008
  • Juli H.
    Juli H. Dec 04, 2008
    Dont be silly- no one would think you stupid because you didnt know of some obscure tech related acronym.
    IC= integrated circuits, but, here is some more information i found regarding the IC diagnosis and your tv:
    "Could be an IC or could be just the output transistor.
    It is a pretty sophisticated circuit and you cannot just replace one
    component and think that is all it will take. It really requires a more
    deep diagnosis by someone or a tech who knows how to check out the
    entire string of circuits in the vertical deflection system.
    You could replace the output transistor and see if that will cure it; I
    would give that a 50/50 chance of succeeding. It is a big transistor
    sometimes mounted on a heatsink, but is usually a separate power
    transistor that feeds the vertical deflection yoke that is mounted on
    the neck of the picture tube. You can trace the wiring back from the
    yoke and look for the markings on the wiring board which will usually
    specify the type of transistor it is.
    Then, if the transistor does not solve the problem you could replace
    the IC - a much bigger job. And requires a very skilled soldering job
    to get the old one out and the new one in. This is not for the faint
    of heart!"
  • 4,806 Answers
System Reset
If the TV does not respond to the remote control,
front panel controls, or will not power on/off, press
the SYSTEM RESET button on the front panel with a
pointed object, such as the point of a pencil or end
tip of a paperclip.
The green LED will flash quickly for about one
minute. When the green LED stops flashing, you
may turn on the TV.
This just might work!!!!
kind regards
  • Lee Hodgson
    Lee Hodgson Dec 04, 2008
    OK try a TV reset this time
    1. While viewing the TV, press MENU to
    display the TV Main menu.
    2. With the Main menu displayed, press
    number keys 1 2 3 to display the
    Reset Menu.
    3. READ THE ON SCREEN WARNING
    AND INSTRUCTIONS.
    • If you do not wish to use this reset,
    press EXIT or MENU to back out.
    • If you do wish to use the reset,
    press ENTER to erase all memories
    and settings.
    This will wipe all the user settings
    good luck
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
My Mitsubishi WD-52631 went "POP"
No,probally a capacitor the help the power supply board to work or other boards to work is blown.Call some tv shops get a best quotes prices,get a tv tech out to it fix,if ur tv is out of warrenty.
Jun 17, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubshi WD-73881 Color problems
It sounds like what your describing is what is called solorization.. whith this model mitsubishi recomends technicians reseat what is called the dvi cable and if that doent work they next recomend replacment of the optical engine. the dvi cable is inside the chais and is what feeds the signal from the main board to optical engine. a large computer type cable like a monitor cable ussally with two tighting thumb screws.
Jan 18, 2009 | Mitsubishi WD-52631 52" Projection HDTV
WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Dec 13, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Smell from mitsubishi wd-52631
Hi...maybe I can help. Go back in and make sure your lamp is connected to the ballast. If it is not all the way in, it will smell like it is burning. Sometime it will even burn out you lamp and or ballast too. Good luck
Mar 28, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi VS-50705
VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Sep 16, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
