Question about Sanyo DS24425 24" TV
Problem with brand new TV
We bought a TV and hooked it up to our local cable provider using a cable that worked before on another TV. We are able to pick up the cable guide to programming just fine but the screen (other than when we are using the cable guide) remains blue. I believe there is a set-up feature that is preventing us from getting any reception but don't know how to address it. The owner's information that came with the TV is minimal. Please help. Thanks, Harry Powe
The TV may be in a Video Mode (Video1,2 or Component2). With the Cable box powered ON, press the Input key on the remote control until you get a picture.
Posted on Jul 17, 2007
    Novelist:
    Champion:
  • 236 Answers
The reason you're getting a blue screen is that you're not getting a signal. Newer TV's have this "blanking" feature to "kill" the snow in the absence of a signal. Check the connector at the end of the cable where it screws onto the set. Stargazer
Posted on Feb 12, 2007
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Feb 06, 2013 | Video Game Consoles & Games
My new HCT LCD TV is not getting my local channels
if your tv is hooked up with cable program as a source their might be problem with the cable provider try to contact for assistance.now if you just only using the areal antenna as a source try re orient first the proper position of the antenna to receive local channel. channel scan much better also either the manual search or through auto channel search . good luck hope this may help.
Jul 21, 2011 | Televison & Video
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
Bought a new VCR/DVD combo. Have TV with cable
Hard to believe you do not have any "F" connectors on the VCR/DVD. What brand is this? You should have inputs and outputs for separate composite and audio. Using phono cords with male ends you should be able to go to and from your television for recording and watching. It will mean alot of changing to go from one mode to the other but should be doable provided your tv has composite in/out. Your owners manual should show a diagram to hook the unit up this way. If you get stuck email me and I'll try to walk you through it. Give me as much info as you can on inputs and outputs. Let me know.
hardrocko
Feb 01, 2010 | Televison & Video
Cable won't work on new tv
When I plug in all of the cables the tv says no signal. I have tried it on all different input settings and my cable provider tried sending me a stronger signal. Could I be doing something wrong and is there anything else I can try?On the back the tv has no receptor what else is there i can use?
Aug 03, 2009 | Insignia Televison & Video
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
Basic cable connections using rear coxial connection
better call your cable tv provider.it seems that the problem is out of your premises
Jan 13, 2009 | JVC AV-56WP74 56" Rear Projection...
NO sound and NO cable signals
Is your tv connected to your cable box through HDMI, AV, or component?
_____________________________
If its through HDMI then your cable carrier needs to load updated frimware in your box to communicate properly with your 2005 tv. The firmware loaded in your cable box needs to be "reverse compatible" for first generation HDMI from your 2005 tv. If your using AV or component hook-up and there's no sound then re-check all of your audio settings within the tv's menu. Also recheck the cable-wire your using and proper input/output ports.
ON your dvd player, is your tv connected through component, AV(rca) or HDMI?
If its through "component" then you need an extra audio cable to and from the DVD and tv.
May 07, 2008 | Akai LCT2060 Television
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Sanyo DS24425 24" TV Logo
77 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
