I got a think pad 600 when i turn it on it tells me i got a problem with the system boardafter testing it it says dev 001 err 91 fru 3610 whats up with it and how can i fix it ? plse help thx
  • uselessmrs Dec 03, 2008
    thx but its very old and will definatly not be under warrenty ...its old but usually reliable... guess it might be time for a new one..
  • 124 Answers
Your best bet at this point is, unfortunately, to call the manufacturer and see what they say. If it's under warranty, you can send it in to them for a fix.
Posted on Dec 03, 2008
HP Touchsmart 600-1000 White screen
Take it in and have it bench tested.
Terry
Sep 13, 2013 | HP Touchsmart 600-1000 Ipp7a-m5...
Is it possible to access the whole C drive when using Ubuntu?
What Can Be Mounted
The most common thing to be mounted is a hard drive partition. Hard drives are kept in /dev and have different names depending on what type of drive they are. IDE/ATA drives are labelled as /dev/hda, /dev/hdb, /dev/hdc and /dev/hdd (since a PC's IDE interfaces can only handle 4 devices at a time). Note that these can be devices such as IDE/ATA CDROMS, Compact Flash to IDE converters, and some special floppy drives (although they tend to appear mainly in laptops). For SCSI devices the labels are /dev/sda, /dev/sdb, /dev/sdc, /dev/sdd, /dev/sde, /dev/sdf, /dev/sdg, /dev/sdh and /dev/sdi (since a SCSI chain can contain up to nine devices). Other types of drive, such as USB, SATA, etc. are mapped to these SCSI devices by Linux. Therefore SATA and USB drives are labelled as /dev/sdX where X is a letter, starting at "a".
Since these are literally the devices you can issue a command such as:
sudo eject /dev/hdc
If /dev/hdc is a CD drive then it will eject.
In the case of hard drives, there is another abstraction. A hard drive (and many devices such as USB "sticks" which act like hard drives) can be partitioned to allow many filesystems to be stored on them. This means that the filesystems themselves are accessible via the partition labels, such as /dev/hda1 (the first partition on /dev/hda). This means that we finally know about something we can mount, a partition, since it contains a filesystem.
Another physical filesystem which can be mounted is the ISO9660 filesystem used on CDROMs. Since there is only ever one CD in a CD drive there is no point creating /dev/hdc1 (where /dev/hdc is a CDROM drive) since there is only one filesystem on it. That means that you can mount CD drive devices explicitly, so if /dev/hdc is a CDROM drive then it is possible to mount /dev/hdc if there is a disc in it.
Floppy disks only contain one filesystem, and are labeled as /dev/fd0 for the first drive, /dev/fd1 for the second drive, etc. So now we know three things which can be mounted.
Devices like USB sticks are treated like hard drives (so /dev/sda1, for example, may contain a filesystem) and so are iPods (although I think the main data on an iPod is stored on the second partition)
Mounting is not restricted to physical devices. If you have a filesystem "image" (which IS a filesystem, whether an exact copy of an existing filesystem, or a filesystem created specifically for that file) then you can mount that through the use of a fake device called the "loopback device"
How To Mount/Unmount Filesystems
Unmounting
Firstly I will tell you how to unmount any filesystem you mount after trying these commands. Unmounting is done through the "umount" command, which can be given a device or a mount point so:
sudo umount /mnt
sudo umount /dev/hda1
Would both unmount the filesystem on /dev/hda1 if it is mounted on /mnt.
Remember that a filesystem cannot be in use when it is unmounted, otherwise umount will give an error. If you know it is safe to unmount a filesystem you can use:
sudo umount -l /mountpoint
Sep 23, 2011 | Microsoft Computers & Internet
My touch pad seems to have lost its use and only an usb mouse plugged in works..have done system restore and that has not rectified problem.. have looked in my computor and it seems to think it is working...
well I can tell you that a fixed a laptop with the same problem and actually what happened is that the person said she dropped it but actually I believe she sat on it and the connector to the mother board touched the circuits and burned it, now if your computer is working maybe the connector came off the bad part is that you have to take it apart to check that a pc shop should charge about 100 dlls to do that.
if it works for you don't forget to rate me
thx
May 22, 2010 | Compaq (153515-001) Touch Pad
I am getting an Error 00301 on an IBM Thinkpad Type 2645, Model 41U, 600, and it boots to a blinking character (looks like a hypen turned sideways)
I ran the diagnostics and had errors on the SystemBoard,
DEV 001, ERR 91, FRU 3610. Upon reading on other sites, it said that the battery is dead and to remove it and run the diagnostics using just the power plug. That did correct the SystemBoard error. It is still running the diagnostics. Next I will see if I can boot the system using a boot disk if necessary.
Feb 08, 2010 | Computers & Internet
ThinkPad 600 System Board error
Have you tried using the reset jumper on the motherboard? I had a PC a few months ago that I had to replace the battery in. I eventually had to use the clear CMOS jumper and the reset BIOS jumper to get the computer to load to BIOS normally. Remember, if you don't have to correct the date and time, then the BIOS has not been reset. Sometimes it is a good idea to leave the PC off and unplugged for about 10-15 minutes to let the capacitors drain down. By doing this after reseting the PC, it gives you a clean cold boot (meaning there is nothing stored and nothing has had power before a reboot).
Nov 10, 2009 | IBM (30L2872) for ThinkPad 600E 2645-55x...
PROBLEM WITH WI FI IT IS NOT DECTECTING IN MY LAPTOP
Have you checked in "device manager" to see if all drivers are installed for your hardware components?
Dec 05, 2008 | Compaq (325489-001) for presario 3000...
Hi i need to know that how to programmed the timer test
you should have your company program this. howerver her is the infor if you know hoe to get into programing.
Option 16: Auto Phone Test (Default = off)
Determines whether the panel automatically performs a periodic
phone test (on) or not (off).
The test interval can be from 001 - 254 days. Entries must be
3 digits. The time of day the panel performs the test is determined
by Option 72: Supervisory Time, which must be
turned on for this feature to work.
Note
For UL 1635 listed systems, Auto Phone Test must be set to 001
days.
 To set Auto Phone Test, press:
1. Add
2. Option #
3. 16
4. Use the numbered keys to enter the number of
days 001 - 254 (all entries must be 3 digits).
5. DONE
 To turn off Auto Phone Test, press:
1. Delete
2. Option #
3. 16
4. DONE
mj
Dec 05, 2008 | GE Security Simon 3 Wireless Home Security...
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Computers & Internet Logo
David Payne
David Payne
