Question about E-Machines M2350 Notebook
Need help with M2350 no power
My M2350 does not charge, does not power on, when plugged in does NOTHING, no light. From doing some research, it must be the motherboard's power "thingee" that went bad (I don't know what it's called). Question is; can I replace that power connector "thingee" on the motherboard, or would I have to get a whole new motherboard?
  • vanamoua Dec 05, 2008
    Thanks dan231 for helping...
    I've tried purchasing a brand new battery, brand new power adapter, even replacing the little plug on the back of the laptop, but none of them worked. The only thing I can't test is the inside of the laptop, that's if it had (maybe) a power controller circuit of some kind.
    I think, I'm going to attempt opening up the laptop and (if it's possible) to switch out the power connector, does anyone know where I can find tips on how to do this?
    I'll post on techie forums...i'll give that a try...
    Anybody know of direct links they can share??
    Sergeant:
  • 236 Answers
The power connect is hard wired to the motherboard and would need to be replaced. Being a laptop, I suggest having it replaced rather than doing it yourself.
Contact a service depot for prices on this. They can also do a diagnostic service which will help to find the real issue, if that proves to not be the power connection.
Can you try a different power adapter to test that first?
Posted on Dec 05, 2008
  • Dan
    Dan Dec 05, 2008
    Search/post on techie forums for laptops. You might get lucky and find someone who has doen that before.
  • Dan
    Dan Dec 05, 2008
    http://www.bleepingcomputer.com/
    they tend to be friendly here.
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
PSP charged all night and will not power on
You're not being clear.
You say "I get nothing"
Do you get a green light? Or no green light?
What if you plug it in? Do you get a green light if it's plugged in with no battery inside?
If you get a green light with the battery in but nothing on the screen, your PSP is bricked.
If the PSP works while plugged in but not with the battery it's either having motherboard problems or the three prongs on the back of the PSP are not making good contact with the battery.
Mar 16, 2010 | Sony PlayStation Portable (PSP) Console
My easynote m2350 laptop fails to boot up.
Are there any sounds like beeps with it? Most likely a hardware issue however, you need to contact support for troubleshooting as without having a one on one conversation it will be hard to rule things out
Oct 04, 2009 | E-Machines M2350 Notebook
Emachine laptop shut down without warning
Test your monitor. To do this, you will need another monitor.
Plug in any desktop monitor to the output port on the back of the laptop. Restart the laptop.
If you are able to use the laptop using this other monitor, then your problem lies in a part called a video power inverter.
It is possible that it could be the lcd backlight, but that is doubtful.
The power inverter is available at many online markets for a relatively small cost. Installation is generally easy enough that any person with reasonable mechanical skills and a set of small screwdrivers can do it.
I once walked an 11 year old boy through the process from 1200 miles away over the telephone.
good luck
tony
Jan 21, 2009 | E-Machines M2350 Notebook
Dell Inspiron 5150 Will not turn on......
had same problem, thought changing power jack would solve problem, but, it turns out the power supply is the problem,, works great with another dell ps
Jan 03, 2009 | Dell Inspiron 5150 Notebook
HP Pavilion dv4000 does not power up.
I have had this happen a couple of times but not sure if its the same for you. There is a small button on the upper right that engages whenever the laptop screen is closed. I was experiencing the same thing when I accidentally brushed the button. I didn't notice anything happen but, I next pressed the power button and it came on???? I guess there is some dohicky in there that triggers the off feature. I haven't decided to ignore this with software yet.
I saw this while researching charging issues where a new battery is installed, calibrated and now will not charge?? any ideas?
Dec 13, 2008 | HP Pavilion dv4000 Notebook
Emachines M2350 laptop- no power
It's one of two issues. 1 - power supply. 2 - the power management chip on the motherboard. Since the power supply is the lesser of the two, try a new supply first. If that doesn't do the trick then it's the pm chip and the motherboard will need to be replaced.
*NOTE* The power management chip recognizes the type of power being used and allows the computer to switch between AC and battery power, it also allows the unit to charge the battery.
Jun 18, 2008 | E-Machines M2350 Notebook
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
AHHHH!!!!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Jul 12, 2007 | Palm Zire 72 Handheld
E-Machines M2350 Notebook Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
