Question about Minuteman Office Plus 500 UPS System
ONLY 2 MINUTES MAX OF BATTERY BACK-UP TIME BEFORE EVERYTHING SHUT
OK, SO I HAVE A REGULAT COMPUTER, AND A MONITOR ON THE BATTERY BACK-UP OUTLETS. WHEN THE POWER WENT DOWN RECENTLY, I DIDN'T HAVE ENOUGH TIME TO GET TO AND MANUALLY SHUT DOWN MY COMPUTER BEFORE THE BATTERY BACK-UP GAVE OUT.
  • 52 Answers
You can program your power bottom to hibernate, and connect the screen direct without the UPS, so you get more time...then when the electricity goes off, without seeing the screen just push the power bottom to hibernate.
Posted on Dec 03, 2008
Acer flat screen monitor
acer monitor v193hqv power supply regulater ic burn so iwant circuit or ic no part no ic 802 problem plse solution
May 03, 2013 | Acer S202HL LCD Monitor
After unhooking Dell monitor, can't get it to work again.
hELLO THERE:
You shouldnt have to hook both of them up.
turn off the computer and monitor unplug. the power cord to the power supply. leave the monitor hooked to the computer
remove the side panel on the left side of the computer.
look and find the wiring harness from the powersupply to the motherboard and remove it now press the power button on the computer for 1 minute this releasess any (esd) or Electronic Static Discharge. that may have built up over time.
wait for 3 minutes
during this time this will be a good time to blow out any dirt or debris that may be in the inside of the computere
now reinstall the wire harness back to the motherboard and connect everything back up and turn on the computer and then the monitor and see what happnes you should be ok after this ok?
let me know how this goes ok and please dont forget to rate the solutions that i have provided for you
best regards michael
(USN RETIRED)
Aug 06, 2009 | Dell UltraSharp 1905FP LCD Monitor
KDS Computer Monitor loses video one half hour after booting up.
first, how long have you had it. if it has intergrated power supply,(does not have a big square box made onto the power cord) nine time out of ten your power converter/supply is going or is bad. return for a replacement. to the manufactuer not the store. they should replace it free of charge, if their honest. samsung has some models with this same problem.
Mar 18, 2009 | KDS K717s 17" LCD Monitor
E-machine was working fine last night got up and it turns on but the monitor says check cable or power but all is ok.Computer wont display anything, can anyone help?
Do a reset: Turn the computer and monitor off. Unplug the monitor video cable from the computer and unplug the monitor power cord from the wall outlet. Let it sit for 5 or 10 minutes. Plug everything back in, turn on the monitor, then start the computer. Sometimes that will work.
If you still have the same problem, try to borrow a known to be good monitor from somebody. If it works, then you know your monitor is bad.
It's also possible that your video circuitry is bad. If the monitor plugs straight into the motherboard (onboard video), then you'll need to purchase a video card and install it. Disable the onboard video first.
Feb 25, 2009 | E-Machines (T2958) PC Desktop
Acer Model AL1916W A reads no signal after being on for 1 hr
The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
Jan 22, 2009 | Acer AL1916W 19" LCD Monitor
Have power cord plugged into asus eee machine and wall outlet. light has been blinking all day. when asus eee gets unplugged it shuts off.
lets try this ---
* turn of your computer
* remove the plug from your computer.
* Remove the battery from your computer
* Let it sit for 3-5 minutes
* Replace the battery
* Plug your computer back in (Make sure the wall outlet is working as well, seems simple, but have seen it before)
* Let it sit for about 3-5 minutes
* Boot your computer
* go to
Start -> Control Panel -> Power Options -> Power Meter
Note the Total Battery Power Remaining
* Let your computer sit for 15-30 Minutes and see if the Total Battery Power Remaining has gone up.
If so problem solved
if not you may be time for a new battery.
Dec 26, 2008 | Computers & Internet
Pilot
tell it to go in normal mode just say sthat when u boot up cuse u shut down inproperley ok might wann buy new video card make sure it pluged in to a hi end power strip ok
Jan 23, 2008 | Computers & Internet
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Sony hmd-a400 monitor
Next time you get it running, right click my computer>properties>hardware tab>device manager and look for your monitor on the 'Monitors' '+' sign and right click>delete. Also check 'Display adapter' see if the correct driver is displayed. Re- boot and let Windows re-install monitor driver(it should list it as 'Sony')
Nov 30, 2006 | Sony HMD A400/L (Blue, Silver) 19 in.CRT...
Minuteman Office Plus 500 UPS System Logo
123 people viewed this question
Top Minuteman Computers & Internet Experts
Larry Chandler
Joseph Hoffmann
Are you a Minuteman Computer and Internet Expert? Answer questions, earn points and help others
