I just hooked my dvd player up to my TV and when I play a dvd I get a strange feedback sound whenever words come up on the screen.
  • 6,487 Answers
CAn you please provide us the brand and model of your player so w cna help you better, By the way did you try to play a different DVD and check if you still have the same problem and also try to use the player on a different TV so we can really check what is the problem here...
Posted on Dec 03, 2008
    Sergeant:
  • 217 Answers
Remove all the connections and refit it properly.and also try with another disc in the player and check out.
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
The audio will not play through the tv from the home theatre unit
because you do not have the dvd player hooked up to the tv, if you want it to play through the tv then you need to have the dvd player connected to the tv.
Mar 21, 2009 | Samsung HT-Z310T Theater System
Suddenly no sound from playiny tv through the dvd
check SCART lead hasn't come out....even a slight amount will disconnect the audio pins
Check the function / to others / setup / connection / AV1 & AV2 settings
Feb 15, 2009 | Panasonic DMRES20D DVD Recorder
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Intermitting blue screen whilst watching my dvd
I'll need more information, but it sounds like an encoded (for copy protection) dvd being played through another device before going to the TV. That intermittent blue screen is usually that. How are you hooking up to your TV?
Jan 02, 2009 | Philips DVP3345V/17 DVD Player/VCR
I can't seem to get my dvd player to play on screen
Set the TV to look for a signal on the same input your are hooking your dvd player to. Example, if your dvd is hooked to video 1, set the TV to show video 1 on the screen.
Dec 31, 2008 | Dell Televison & Video
Lightning mcqueen tv and dvd set-up, won't play, have direct tv hook-up
i guess there a built in dvd player on the set and it could play most DVD format.
but if you wish to use another dvd player
hook up the dvd on the tv
video output (DVD) to video input (TV)
audio output to audio input
the find the auxiliary button from either the tv or dvd
Oct 30, 2008 | Disney DTD1363-CAR 13" TV/DVD
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
