Question about ViewSonic VA712B 17" Flat Panel LCD Monitor
Viewsonic VA712b 17 " flat screen monitor
I just bought this monitor today, and can't get it to work. It worked for about 2 minutes, then began to flash back and forth from the screen to a black screen and then finally just went black completely. If I don't wait and try again immediately, the screen is totally black. If I wait a bit, it does the screen changing thing and then goes to black. I should mention that when the screen is lit, it seems to be shaky, as if some sort of current/disturbance is present. The computer I am using is a DELL Dimension 3000. Thing is, it seems to work fine when I plug into an old laptop (also a Dell) that I have. What's the desktop PC missing that the laptop has got? Or what's going on here? I read several of the other tips, but did not seem to see any that had to do with a brand new monitor... thx-
  • Anders Porter Feb 05, 2007
    tomj23-
    Thanks so much for the advice. Unfortunately, nothing worked. I was on the phone late last night with more comp savvy friends, NONE had any clue, seeing that since I was using the VGA connection, and had used a similar monitor before, things should have worked. I uninstalled drivers and reinstalled drivers... changed the parameters as you suggested and still... no go.
    Sooo, today I took that one back and exchanged it for a VGA only, little larger widescreen (Viewsonic VA1912w 19") and brought it home, plugged it in and all is good. So the DVI port was not able to be recognized, even though it was not being used??? I don't know. But for the time being, I'm happy.
    I am still a little weary about viewsonic, even though I can't really afford to be. The monitor that I just brought home had a power supply cord that I think is for Egypt. I am in Sweden. Thankfully, I have extras lying around.
    anyhow, thanks for your help. I'll let you know when it explodes or melts or something.
  • 624 Answers
Realheadache, Unusual problem, it could be the resolution and refresh rate setting your PCs video card is currently set at. I don?t know if this will fix your problem but its worth a try: - Now go to your PC with the old monitor connected, right click anywhere on the desktop. - Left click Properties from the box that appears. - When the Display Properties box appears click on the Settings tab. - Make note of the screen resolution. - Change the screen resolution to 1024 x 768. - Click on the Advanced button in the lower right hand corner. - In the next box that appears click on the Monitor tab. - In the Monitor settings section of this page record the value of the Screen refresh rate. Then change it to 60 Hertz. - Close this and the Display Properties box by click on the OK button. - Now try connecting your new monitor. Let us know if this helps and as always please don?t forget to rate this posting.
Posted on Feb 05, 2007
What is the procedure for disassembling the VA712B monitor?
mercoman, Do not use any sharp cutting instruments. See disassembly VIDEOS on YOUTUBE of typical PARTING of rear cover from front bezel. Start at bottom edge looking for place to insert dull flat-blade screwdriver. Use caution. 12fixlouie
Mar 04, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
There is no sound from my va712b monitor speaker
1. check the quarter inch connector to the speaker input to the PC make sure that you have all cables to connected to the PC and the monitor.
2. Check drivers for the monitor and reinstall /
3. Go to the "Device Manager" and check for conflicts and check to see if the driver need to be updated. An exclamation next to that device means that there is a conflict.
Jan 29, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Green/blue/purple vertical bars on my viewsonic va712b
you're video card is failing, try the secondary port if you have one, artifacting such as different colors, shapes and lines are VGA related, you need a new VGA card and for more info contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Flat Panel LCD Monitor goes dark for 2 sec then back on
sounds like the backlite bulb is failing. best thing to do is to take it in and have it checked if is worth the cost. some can be replaced, some cant.
Jun 05, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Problm with viewsonic va712b
It may also be a problem with your video card, I've already seen a problem likewise, try to remove and replug your VGA card and try again, if you can try to plug another screen on your PC and to plug your screen on another PC, then you'll be sure
Nov 05, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
Screen
You can resolve this by pressing Ctrl+Alt+Up key if that doesnt work go check your graphics card for hotkeys.
Jul 07, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Feb 26, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
Open Questions:
ViewSonic VA712B 17" Flat Panel LCD Monitor Logo
378 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
