Hi I can connect my linksys usb but I cannot connect to internet as it saying limited or no connectivity all the time which won't let me connect so pls help
    Problem Solver:
  • 14 Answers
You might not getting proper connectivity from your internet service provider
so just check your internet connection setting then your computer's IP address configuration
if its working ok
then you have to ask your internet service provider for additional help and perticular settings
Posted on Dec 03, 2008
I just got a linksys wireless router and got Internet but my Dell inspiron 11 3000 won't connect to the Internet the wifi says limited with no internet why is that can someone help me out please
sounds to me with that type of message that machine has connected to router. but router is not connected to modem/switch depending on what type of internet you have
if router has usb ports and you plug a thumb drive into it and pc can see that drive yes my thoughts are correct
Nov 30, 2015 | Linksys Computers & Internet
Why is limited internet connection?
You are facing the limited internet connection only when its secured with the username an password.
Check for it or contact your ISP.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com
May 01, 2013 | Linksys WRT54G-TM Wireless Router
Why cant i get on internet threw my wirless linksys rangeplus wireless notebook adapter even though it says i have 100 per cent connectivity there is a window poping up saying this connection has...
well first u have to config the wireless..making sure it has full internet access...or the ap to the internet needs to be checked and enabled, it must be shared.
Dec 28, 2010 | Computers & Internet
Router problem
Hi .
First who is your service provider?
Can you connect to the internet if you directly hook your modem to your computer.
1>If so connect your Modem to your router on the colour code slot on the router which says modem
2>Connect a cable from the router to your computer
3>The lan light on the router should be turned on
4>Check wether your lan says connected . To check that click start-> control pannel -> network connections
5>If it says connected try internet explorer settings
6>If it says limited or no connectivity
Click start ->run -> cmd->ipconfig
7>It should say ip address as : 169.254.x.x.
8>If so type ipconfig/release
9>It shoul say ip address: 0.0.0.0
10>Type ipconfig/renew on command promt
12>Disable and enable lan
Let me know if this helped and also if you dont what kind of messages you get .
Mar 02, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Limited or no connectvity
you can use the WinSock XP Fix tool to reset TCP/IP protocol to original state: http://www.snapfiles.com/get/winsockxpfix.html
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Limited connectivity
check your ip adreses
it is range of router
Linksys Wireless G USB Adapter does not connect to the Internet
well do on ething first .... when u try to connect to the network ....
there would be an advanced option there or in short it would be an option for removing the prefered networks .....
remove every prefered network from there ....
Aug 23, 2008 | Linksys WUSB54GS 802.11G USB Adapter...
Connected to rounter but not internet
Normally this means that you are not putting in the security key or wireless key. Click on the linksys software then go to site survey select your network then click connect and type in the correct security key.
Jul 25, 2008 | Linksys WUSB54GS 802.11G USB Adapter...
Connection problems
If Internet sharing is set up correctly one pc will be the one that connects directly to internet, the other will connect through a gateway or other device connected to your network. Check they have'nt both got the same IP address. Is this related to last problem, did you get the wireless card working wirelessly online?
Nov 20, 2006 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
