Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Belkin wireless g plus mimo router
I have a compaq desktop computer that runs on cable internet. I bought this router thinking that it would do the trick to hook my acer laptop up to to share the same connection. But after hooking up the router the problem that i have incurred is that the connection works for my laptop but now my desktop will not connect to the internet even though it shows that it has connectivity, it will not let me bring anything up on the internet. I called my service provider and they say that this problem isn't even possible. I need some major advice here!
  • Melissa Mullins Dec 03, 2008
    I have ethernet
  • Yasser Mahmood
    Yasser Mahmood May 11, 2010
    do you have a dial up over the network???
    Scholar:
  • 118 Answers
YOu may have configured static ip address in your desktop computer...
CHange IP setings to obtain Ip address automaticaly.....
or follow
  1. Open Windows Start menu.
  2. Open Control Panel.
  3. Classic view: Open Network Connections
    Category view: Select Network and Internet Connections, and then Network Connections.
  4. Double-click on your active LAN or Internet connection.
  5. Click Properties.
This opens the Local Area Connections Properties window.
  • In the General tab, highlight the Internet Protocol (TCP/IP) item, and click Properties.
  • In the General tab, click
    Obtain IP address automatically....
    and click ok...
    and try to conect it now...
    Let me know it this helps.... GOod luck...
    rate me..
    Regards,
    Posted on Dec 03, 2008
    I bought belkin g wireless modem ruter but they didn't give me CD . How can i install this and how can i use my wireless ruter please. Thank you.
    Power-off your cable-modem (or DSL-modem).
    Use an Ethernet cable to connect from the modem to the WAN port on your router.
    Use another Ethernet cable to connect from one LAN port on your router to the network-port on your computer (desktop/laptop).
    Turn the modem on.
    Turn the router on.
    Turn the computer on.
    Click Start
    Click Run
    Type CMD
    Press Enter
    Type IPCONFIG
    Press Enter
    Look for output like:
    Default Gateway . . . . . . . . . : 1234.678.0.1
    Start Internet Explorer
    Type http://1234.678.0.1
    to access the web-server "inside" the router.
    Run the Network Setup Wizard.
    Run the Wireless Networking Setup Wizard,
    to pick an SSID, an encryption-level (use 'WPA')
    and to pick a network-password.
    Now, you can disconnect the Ethernet cable from the computer, and try using the wireless-adapter inside your computer.
    Sep 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Do i have to go wireless with the (belkin wireless router g plus mimo)? or can i run ethernet cables from the 4 ports in the back of router to my computers?
    you can run wires to create a WIRED network. just enable DHCP in your router so that you will get IP addresses dynamically. While you have WIRED network, your wireless network can also be used at the same time for your wireless devices.
    Sep 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Modem light blinking and no internet in the wireless router. but when i run a cable from my modem to my computer, internet works....but when i rund the cable from the modem to the belkin wireless...
    you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
    Apr 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Problems with Belkin Wireless G Plus MIMO Router
    - Nope, it is not possible, you may need an Access Point to do it.
    Mar 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    How do i get connection using belkin wireless g plus mimo notebook card i have only the card is there still a way i can connect only having the card that goes to my laptop. or do i need a router or can i...
    1. If your laptop has a built-in wireless adapter, then you don't need a belkin wireless g plus adapter.
    2. You can connect to the Internet using your adapter provided that the location where you at offers wi-fi or wireless connection
    3. If you want wireless connectivity at home, then you need to have a wireless router and subscribed for DSL/Cable broadband connections
    Nov 07, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
    Shutdown your PC. Unplug the power from the router and the cable modem.
    Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
    here is a website to help you setup the Xbox Live:
    http://support.xbox.com/support/en/us/xbox360/XboxLive/GetConnected/SetupaHomeNetwork/HomeNetworkingBasics.aspx
    You may have to copy and paste the link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Sep 06, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Slow Internet using Belkin Wireles G Plus MIMO
    Try setting the MTU size to 1400 and also check if there's any firmware update for it if there is update the firmware.
    Hope it help
    Apr 22, 2008 | Belkin (F5D8231-4) Wireless Router...
    Help please intructons are not helping
    The fixed cable from the modem should be plugged into the computer, remove the modem cable from the computer and plug it into the 'internet/wan port" on the back of the wireless router. start the router and connect to it wirelessly. BPCS
    Dec 27, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
    108 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
