Question about Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d mode dial does not select modes
When I try to change from manual to auto or other modes it either stays on manual or selects modes other than the mode indicated on the dial Same problem with a Canon EOS XTi Digital - Only about half the modes work on selector dial,example I am unable to eect Auto or night flash mode with top right selector switch...
  • barry6386 May 11, 2010
    Make sure you are not in some custom Setting or function. I suppose it is possible the selector dial is stripped and it is just spinning and not doing anything.
  • 25 Answers
Looks like you need to take this to a camera store and have them check it over. I don't know of any setting that would cause what you describe.
Posted on Aug 15, 2009
How do I set my Canon EOS Rebel T3i 18 MP CMOS Digital SLR to auto mode
If you mean the auto exposure mode, turn the mode dial on the top of the camera to the "A+" position, between the "P" and the lightning bolt.
If you mean autofocus, set the switch on the lens to the AF position if the lens has an autofocus switch. On the camera, press the AF button (cursor-right) then turn the command dial to select the desired mode.
If you mean the auto white balance, press the WB button (cursor-up) then turn the command dial to select the desired mode.
In the auto exposure mode the ISO mode is set to auto, and you can't change this.
If you need a manual, you may download a copy here.
Feb 02, 2012 | Canon Cameras
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My EOS 400D takes blue hued pics
You may have the white balance set incorrectly. If so, set it to "auto white balance".
Sep 25, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
Jul 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon 300 EOS images
This could happen if you're using flash and your shutter speed is set too high. If you're not set to Program or Auto mode, try changing to Program mode and see if that solves your problem.
Otherwise, it sounds like a sensor issue. Call Canon support - I've found them helpful. Check the website for phone number.
Mar 07, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
400D manual mode
You are exposure compensation in manual mode. If you want the shots lighter, either open up the aperture or slow the shutter. The exposure compensation feature is to override the automatic settings determined by the camera in the auto-exposure modes.
Dec 05, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Only about half the modes work on mode selector dial
Sounds to me like the internal contacts aren't working correctly. Let your local camera store take a look. Hope it's under warranty.
Dec 03, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Return to full auto setting
To set the camera to shoot fully automatically (camera selects f-stop, shutter speed, exposure, etc), turn to Mode Dial to the green rectangle icon, right next to the "P" on the dial.
To reset all settings to their original default settings, the procedures are on page 100 in the manual.
1. Press the Menu button and use the Jump button to go to the Setup 2 menu (far right).
2. Use the arrow keys to scroll to "Clear Settings" and press the Set button.
3. Scroll to "Clear all camera settings" and press the Set button.
4. Scroll to "OK" and press the Set button.
Sep 18, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Choosing to shoot Raw images
If you have Rebel XTi (400D), press Menu button.
Under the 1st Tab, the first option is "Quality" - select it. You should see 8 options from "fine L" to "Raw". Move selection using the arrow keys, and select RAW.
Mar 25, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Speedlite 540EZ and EOS 400D
540EZ will not work on digital Canons in auto reading mode. It will only work on manual flash settings.
Mar 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera Logo
516 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
