Question about Car Audio & Video
My car battery went flat and I had to jump start my car, unfortunately my car radio was switched on at the time and now the display says 'READ' constantly and the radio doesn't display what is on either the i-pod or cd player. How do I rectify this problem?
    Problem Solver:
  • 22 Answers
Find the reset button. If there is no reset. disconnect the neg. (-) cable on battery, reconnect. look in owners manual.
Posted on Dec 03, 2008
Battery went flat radio wont work now.how do i get code?
Search Results
    Car Radio Stopped Working after the Battery Died
    cartech.about.com > ... > Car Radio Components FAQs, and More
    First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
    radio won't work after new battery installed - Car Talk
    community.cartalk.com/.../radio-wont-work-after-new-battery-installed
    Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
    Another Flat Battery - Radio No Longer Works - Hyundai Forums ...
    www.hyundai-forums.com/.../128744-another-flat-battery-radio-no-long...
    Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
    Dead battery..now radio won't work - Honda CR-V Owners Club
Dec 09, 2015 | Cars & Trucks
My bettery went flat on my rover 45 impressions 02 plate now my radio wants a code it just say code wait on the display. can any1 help me plz
Try '0000'. If not, you need to take it to a car audio specialist. I have also read that if you remove the radio and put it in a freezer bag in the freezer for 24 hours, it clears the memory!
Nov 24, 2013 | 2000 Acura TL
05 nissan almera 1.5 control panel not working
Sounds like on your first attempt to jump start the car the positive and negative cables were reversed blowing your main fuse. Your interior lights are usually controlled by a switch next to your speedometer or the dashboard. If the switch does not bring the lights/gauges back then it is possible that something else shorted and the vehicle would need to be taken in for service.
Nov 16, 2013 | Cars & Trucks
My car wouldnt start, the electrical system starting going crazy (radio going off and on, etc) then when I went back outside to my car the lights were going off and on by themselves. any ideas?
could be a sign that the computer is failing-though they usually are durable--try disconnecting batt a few minutes and see if it clears and chec for any wiring flaws--get vehicle scanned also--reprogramming a computer should be done before buying a new one
Nov 28, 2010 | 2004 Chevrolet Monte Carlo
My battery went flat the other day and i put in
If it is saying code 2, thats not a code to input anything. Its a error code for a hardware malfunction.
May 03, 2010 | 2002 Hyundai Accent
Sony ICF-C211 Clock Radio started to display minutes:seconds only instead of showing hours:minutes. I guess, I might have pressed certain combinaton of buttons to start this. Unfortunately, I do not know...
might not be the solution but similar happen me and i went back into time and after awhile found reset,so jus keep trying,if not,turn off unplug for 24 hours and it should flash all zeros when plugged back in,but make sure no batteries in it,lol
Jan 16, 2010 | Sony ICF-C211 Clock Radio
Ford Mondeo - ?Battery not getting charged after jump starting!
YOUR BATTERY SOUND LIKE ITS DEAD. CHECK BATTERY VOLTAGE SHOULD BE 12.5 VOLTS IF NOT TAKE IT TO YOUR NEAREST AUTO ZONE OR ADVANCE AUTO.LET THEM TEST IT LOAD TEST IT.WHEN BATTERY IS CHARGED OR REPLACED.WITH ENGINE RUNNING ALTERNATOR OUT PUT VOLTAGE SHOULD BE 13.5 VOLTS TO 14.5 VOLTS.IF NOT HAVE ALTERNATOR CHECKED.IF ALL GOOD YOUR ALTERNATOR FUSE / FUSE LINK BLOWED OR YOUR ALTERNATOR WIRES IS DAMAGE.OR DRIVE BELT SLIPPING.REMEMBER TO TURN OFF RADIO BEFORE DISCONNECTING NEGATIVE.BATTERY CABLE.IF YOU DONT YOU WILL LOSE RADIO CODE.RADIO WILL NOT PLAY.
Aug 30, 2009 | 2002 Ford SVT Focus
Vauxhall astra s reg
One of two things has happened
Because your battery went flat and you then created a short circuit the radio may be locked out and need a start code which should be in your manual
Worse case is that by applying a reverse polarity to the radio you have blown the protection diodes up inside it, if so it is a back to the maker job
Aug 19, 2009 | 1996 BMW 318
Radio not working after jump strart
You need a code to enable your radio. Happens every time the battery is dead or disconnected. Contact a Saturn rep.
May 21, 2009 | 2006 Saturn ION
I have a car jump starter unit that was left and went dead flat. Now it will not take a charge pluging in the charger?
Unfortunately, a Jump Starting Unit which no longer takes a charge usually means the internal batteries had gone bad. On some charging units, the replacement batteries are available through the manufacturer, but more times than not, it's less expensive to replace the Jump Starting Unit.
Nov 09, 2008 | Energizer Rechargable Battery with Charger
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
