How to fit ribbon
How do you fit the ribbon
  • Dick O Reilly May 11, 2010
    Make and model is necessary
    DickyO
    Scholar:
  • 183 Answers
Too many ways to say without the make & model
Posted on Dec 06, 2008
The intermec is show a "ribbon fitted" error on the machines screen
its because the printer is setup Direct Thermal, and the sensor see ribbin present. need change setings.
May 21, 2010 | Intermec EasyCoder® PX4i Label Printer
The "ribbon" pulled out
If you mean one of the ribbon cables, they usually go into a thin clip. This clip often has a releasable pressure fitting. Look for where you pulled the cable from and see if the fitting is two toned. If so use your fingernail to either pull the flap forward, to back.. various types. Place the cable back into the slot and press the clip back down.
If the ribbon is a (usually) white cable with a hard clear or blue end, then it likely goes into a solid pressure fitting. Just grab the hard plastic tab and push it back into the slot.
Feb 15, 2009 | HP Officejet 7310 All-In-One Printer
Samsung u600 ribbon cable. how do you fit ?
probably not the screen more likley the ribbon connecting screen to keypad try you tube for a instructional video
Jan 02, 2009 | Samsung SGH-U600 Cellular Phone
Bad print out
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Dec 30, 2008 | TallyGenicom 2348 24WIRE 480CPS Draft 136...
2265+ ribbon error
The Ribbon can only be installed correctly as you have to lower a bar after to allow the printer to start if it was in incorrectly this arm would not lower and you would get no printing.
Instruction manual will explain better
http://www.softwaredriverdownload.com/download.php?file=964rxfbkkrZnRwOi8vZnRwLnRhbGx5Z2VuaWNvbS5jb20vcHViL2dlbmljb20vZG9jcy90YWxseS9zZXJpYWwvdDIyODAvMDYzMDUwYV9vbTIyNjVfZ2IucGRm
Dec 27, 2008 | Tally T2265 Dot Matrix Printer 917402
Removed Laser ribbon
sorry a ps2 **BIG SYSTEM** wont fit ..now the ribbon in some of the old ps2 are thin insted of the wide type and they may fit but if i understand your ? right a ps2 lazer wont fit
Oct 23, 2008 | Sony PlayStation 2 (PS2) Console
Ribbon supply
This ribbon fits many different typewriters 25 and 35 are the same. Spool should be the metal type not the plastic, and you need the nuts on the top....
Mar 20, 2008 | Olivetti Lettera 35 L Typewriter
Fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
Oct 28, 2007 | Smith Corona Wordsmith 100 Typewriter
54 people viewed this question
jasbo
jasbo
