Question about Baby Gear
Jane powertwin carrycot/car seat
Can i use the matrix pro or do i have to use the rebel car seat with my powertwin pram? Also,dothe clips for car and pram come with the seat or do i have to buy them separately?
Thanks for your help.
  • mummyz Jan 12, 2009
    I was wondering the smae lookin to buy the jane powertwin for a toddler and a newborn but would like to know if i can use a matrix car seat on. i know you cant use it in a lay flat postion but can u use it in the other postions? thanks x
  • 419 Answers
With the Powertwin, you can only use the Rebel carseat. With the newer model 'Pro Generation' Powertwin, you can use the Strata carseat also.
It sounds like you have a non-pro version, so you should only use the Rebel Non-Pro carseat. You would normally get the adapters with the Powertwin (one set is grey and one set is black, you get both with the pram) but if you don't have these, you can contact www.johstonprams.co.uk who will sell these to you.
I hope this helps.
Posted on Sep 20, 2009
  • Liz Wanden Sep 20, 2009
    Hi Mummyz,
    With regards to your issue, if you are buying the new Pro version Powertwin then you can use either the Rebel Pro or Strata carseats, unfortunately the Matrix can only be used on the Twin Two double pram.
    I hope this helps.
Jane Powertwin pro - how do i fix the raincovers on to car seats
When you are using the carseats (Rebel or Strata I expect) then make sure that the carseat handles are in the upward postition (as they would be when you carry them) the handles will then support the raincover.
Hope this helps.
Mar 30, 2010 | Jane Powertwin Jogger
I have bought Jane Powertwin Pro and Jane rebel pro car seat but i couldn't fixed the seat on the pram
To place te Rebel Pro car seat onto the chassis, remove the hood from the back seat and where this was attached, there will be a rectangular hole either side, this is where the Rebel Pro will click into.
I hope this helps.
Nov 13, 2009 | Baby Gear
Need new front wheel and seat liners for jane power twin
If you need to purchase any spares for the Jane prams, I suggest that you contact the UK distributers, www.johnstonprams.co.uk who, I am sure will be of help.
Sep 07, 2009 | Jane Powertwin - Navy Jogger Stroller
On jane powertwin the front wheel shakes when locked into position
If the front wheel is shaking, I would suggest this:
Lift the pram so that the handlebar is on the floor and the front wheel is in the air, this way you can see directly underneath the mono-fork (the fork which is attached to the front wheel). At the bottom of the mono-fork there is a very small screw (or hole if it has come out) this can be tightened with a very small allen key. If you have a hole there, then the screw can be purchased from www.johnstonprams.co.uk
However, this only applies to Pro versions of the Powertwin, If yours is a non-pro, then again, I would suggest that you contact Johnston Prams to get them to give you a guide to adjusting the brakes on the front wheel which should stop the wobble fine.
(N.B. If your model is a Pro, it will say on the chassis 'Pro-Fix' or similar)
I hope this helps.
Sep 03, 2009 | Jane Powertwin - Silver Jogger Stroller
How do i turn the front seat on the jane powertwin?
The front seat on the Powertwin does not turn. It only reclines by lifting the handle in the seat back. I rear facing Jane Rebel car seat can be fitted in place of the front seat using special adapters
Aug 15, 2009 | Jane Powertwin Jogger
I need two hooods for my red Powertwin Jane stroller
The official UK distributor for Jane is Johnston's prams http://www.johnstonprams.co.uk/ they should be able to help.
Aug 13, 2009 | Jane Powertwin Jogger
Jane powertwin has stains on seats do covers come off for washing
I normaly Scrub the seats down with some stain remover and hot water on a sunny day, or ona day when it is dry. Then leave them to dry, and they come up pretty good.They only detach from the pram as a full seat so not able to put in a washer.
Jan 11, 2009 | Jane Powertwin Jogger
Fitting jane powertrack 360
Are you attempting to place the car seat onto the stroller? If so then I can help as I have a powertrack 360 with the matrix car seat.
Jan 03, 2009 | Jane Powertwin Jogger
Jane Powertwin
This is exactly what my husband did to our powertwin just 6wks into using it he managed to twist it slightly back into position and it holds so we have just put up with it but my god was I pissed at him! I was told it could be repaired by replacing the seat unit by a local pram shop but this seemed expensive we have managed with it like this for a yr no problems hope this helps.
Jan 14, 2008 | Jane Powertwin Azulon Stroller
Baby Gear Logo
1,199 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
