Question about Dryers
No heat coming out the tumble dryer
There is no heat being produced from my tumble dryer it is still going round but only cold air
  • 5 more comments
  • eye Dec 04, 2008
    Its an Electra and it says on the front 279 so I take it thats the model no of it.
    thanks
  • eye Dec 04, 2008
    Hi I have found the model no it is 37279002AL. I think I have found the problem, there is a sort of contact breaker attached to the element by wires I flicked it and the element lit up but not all of it some stayed unlit so I guess the element needs replacing. But I cant see how to get it out It is just there right in front of me but everything seems to be riveted I don't see any screws to undoe and just lift it out??. Also this contact thingy keeps clicking and you see a small spark which seems to keep turning the element on and off. Do you have any idea how to get this element out?? thanks for all the help its much appreciated
  • eye Dec 04, 2008
    So what do I do to stop it sticking or do I have to replace it? if I need to replace it whats it called so I know what to look for. So are you saying that the element is ok then and I don't need to replace it.
    thanks
  • eye Dec 05, 2008
    that is good news but if I decide to leave it alone and not change it how can I stop it from sticking in the open position. As it is doing this everytime I switch it on the only way to get it working is to take the back of and give it a flick. Obviously this is not ideal
    thanks
  • eye Dec 05, 2008
    with your great help I have managed to find that part and have ordered it, hopefully will get tomorrow. Fingers crossed it will solve the problem I will let you know. Couldnt have done it without you brilliant site keep up the good work it is very much appreciated
    thanks again for taking the time to help me
  • eye Dec 12, 2008
    Hi well I put the new T.O.C on which I received today, and it is doing exactly what the other one was doing. It just keeps clicking on and off the elemant only stays on for about 20 seconds and then it sparks and turns it off for about 5 seconds then sparks and on again for 20 seconds. I had the dryer on for about 1 hour with 2 towels in it and they came out just as wet as when I put them in. So the mystery now is what is making the T.O.C click on and off so rapidly and not givie the elemant a chance to heat up and stay on long enough to dry.
    thanks
  • pedropony2 May 11, 2010
    what make is it plz
  • 135 Answers
Electra is brand name for what was yeb so could have been made by several companys. Please check at back of drier for red reset button or rectangular plate at bottom right corner.
Posted on Dec 04, 2008
  • 1 more comment
  • pedropony2 Dec 04, 2008
    It is meant to do that to prevent burnout of the element. they sometimes get stuck in open position which stops heat.Also the element will not all heat at the same time.
    regards.
  • pedropony2 Dec 05, 2008
    Your element is ok. While the thermal cutout is working its better left alone as they usually fall apart when removed. On the plus side they are very cheap and readily available. If you go to your local appliance spares shop and tell them its electra made by hotpoint they should know what your after.
    You could try to clean the contacts if you can tease it out without breaking it.as a temp measure you could bridge the 2 wires to do some urgent drying.
    gonna catch some zzz now but happy to have helped.
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
The tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
An indesit tumble dryer, only blowing cold air.
Most likely heating element or thermal cut-off is bad, or both.
Sep 14, 2017 | Dryers
Tumble dryer not going round
It's probably a broken belt. You don't say what kind of dryer it is, but most of them have a belt that couples the motor to the drum.
Mar 15, 2009 | Washing Machines
Dryer tumbles, no heat
Fist thing to check is if the manual reset on the heater box has tripped. That dryer can be serviced from the front. Also, there is a heater upgrade kit that can be purchased from Fisher Paykel Parts that has several updated parts in it for the top load electric dryers.
There are several things that can cause the reset to pop out. You may have a lint build up behind the shroud where the lint bucket fits.
This is a complicated appliance. You may wish to obtain a service manual for it.
Link to factory service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Link to heater upgrade kit:
http://fisherpaykelparts.net/index.php?categoryid=112&productid=32
Dec 17, 2008 | Fisher and Paykel DEIX2 Electric Dryer
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
My indesit condenser tumble dryer is only giving out cold air. it is not heating up?
Common faults -
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
May 02, 2008 | Dryers
Dryers Logo
434 people viewed this question
Top Dryers Experts
