Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
Toshiba 65 hdx
Had two repair men out to look at my tv,(first guy could not understand why closing the door change picture to black anything above 480i). Touching av board the picture cut in and out so I replaced it. Not having any faith with the toshiba refered techs I changed it myself. Worked for awhile then went out,second Tech comes in and said it might be the hyper module. Well might and 500.00 dollars didnt cut it for me so I ordered the new module online. 4 month nationwide backorder, odds were with me when I heard that. 6 months later or two weeks ago I installed the new module and turned the tv to discovery HD, 4 year old set and it looked as good or better than tvs at circut city with there little digital input boxes (misleading to the consumer I think), The hyper module lasted 2 weeks exactly now Im back to 480i, sometimes it blacks out and anything above that is just black with audio. Was I on the right track? Oh ya the supplier said since I mounted it in the set there will be no returns. Did not solder in the hyper module,did not see any connection in the board to need solder. Is it just a mechanical joint to hold module in place during shipping? Thanks for your time Scott Kelley
  • 128 Answers
SOURCE: Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Posted on Jan 19, 2006
  • 1694 Answers
SOURCE: Is my Toshiba 57H81 worth repair?
Bounce horizontally usually means up and down,which relates
to the vertical output IC. Solder IC301, IC401 pin connects==try
again.You can easily isolate "bounce" problems by lightly
tapping on the vertical IC heatsink....Let me know if you need
further assistance.....T.
PS. Though hard to find, a qualified tech could do that repair
in home for 300. to 400.00...
Posted on Oct 20, 2007
SOURCE: light engine
where are you getting your parts from? sounds like someone may be selling you used parts to get more business.
Posted on May 16, 2008
  • 126 Answers
SOURCE: Toshiba TP48C90 Convergence (replaced ICs, worked for 2 days)
Well, my thought is that there are a ton of knock off generic convergence IC's out there that usually hold up as long as yours did. Professionals like me will only use Sanyo original STK's. The counterfeit STK's out there are everywhere. Do some research on the web to locate Sanyo originals, they are out there.
Posted on Jun 11, 2009
ladywinn
  • 5138 Answers
SOURCE: I heard grinding or humming noises for about 6
ColorWheel /Visit Encompass Parts Distribution and type in your Model#
they will list parts and prices 1-800-638-3328
Posted on Dec 27, 2010
Yellow blinking light on toshiba tv
http://aaaateva.com/tv-repair/tv-brands-serviced/toshiba-tv-repair/toshiba-tv-codes
the color and blink pattern of your tv led is a code that gives you the fault...check at the site above.
Jul 05, 2015 | Toshiba 65HM167 65" Projection Television
Lamp went out on the tv. We replaced but there is still no picture and the TV keeps resetting .
okay you have to make sure you close the door that the buld goes into there is a liitle micro switch that only triggers when the cover is removed it stops the tv from lighting up the bulb once you close the door and all are put back together properly the tv will come on if it dosent you need to read in between the flashing codes
Jan 27, 2011 | Toshiba 65HM167 65" Projection Television
Picture does not fill screen
hey this dave from tupelo ms i have found the man of men , this guy fixed my problem with mt 65 in tv with little whites dits all over i found him on ebay, his name is HONG BUI hes a ex- mitsubishi tec who went out on his own hes great i sent my light gen to him andhe fixed it perfcetly for just 150.00 were evryone else said it would cost 750-1000 dollars heres his info HONG BUI TVB Servise houston tx 713-401-7701 check out his web site on ebay and he will help you
Jun 07, 2010 | Mitsubishi WD-65C9 65" DLP HDTV
Shrinking Picture
problem is bad soldier on the vertical IC , this part needs to be resoldier to solve your problem, its a simple job for any tv repairman.
Jan 10, 2009 | Toshiba 36A40 36" TV
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Power light blinks and no picture
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Toshiba 65HX81 65" Rear Projection...
42dpc85
You have a cap on the powersupply going bad. it can be replaced but you will have to take the back of the unit apart to find out witch one it is. look for one that is swelling at the top.
Jul 25, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
