Question about Fujitsu fi-5530C Scanner
Fujitsu fi-5530C scanner persistent "ADF open" error
Fujitsu fi-5530C scanner jams occasionally and this is expected. However, frequently after clearing a jam and restarting, the scanner will stay on "P" mode and will not scan any documents or make any sounds. Message says the ADF is open, but attempts to re-close it have no results. We have found that restarting both the computer and scanner multiple times seems to eventually clear something, and then opening and closing the lid one more time will suddenly will bring it back to life. It then resets itself and works fine. We cannot seem to find a pattern of the shut down and restart sequence that corrects the problem, so it's just multiple tries until it works. Does anyone have any idea what is going on here?
  • mbourcy Apr 01, 2009
    We have the same problem.
mohanchennai
  • 490 Answers
SOURCE: fi 5750c adf will not initialise
Clean the rubber rollers in the ADF with a well wrung cloth thoroughly. Use IPA (Isopropyl Alcohol) if reqd. Dont use any other solvents.
S. Mohan
Posted on Mar 14, 2008
  • 8 Answers
SOURCE: Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
Posted on Jul 15, 2008
  • 3 Answers
SOURCE: How to disable Fujitsu fi-5750C ADF
Your scanner will never pass the initial boot "test" sequence without getting sensor and light readings. Cut the binding and scan it through the adf and save a few weeks work.
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: Fujitsu fi-5900C jams
there are many optical sensors in the paper path, you need to clean all. if not solved, reply with error code with detail code
Posted on Jul 03, 2009
  • 16 Answers
SOURCE: E3 error on fujitsu fi-5530C
You have a rear optical error.
check the lamp is lighting.... open the ADF and push in the cover open switch. if one if off, replace it or the lamp inverter
swap the cameras over to be sure the fault follows to an E2
replace the optical unit
good luck
Posted on Sep 17, 2009
Error Code : 0x5a
The detail code 5a in Fujitsu fi-5900 scanner is displayed due to frequent paper jam error. To resolve this issue, you need to clean the two lenses of JAM1 sensor and check it's performance.
Also, to resolve paper jam error, you need to check the condition of pick,separator,brake rollers, feed and pinch rollers. Replace the rollers if required.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Aug 01, 2014 | Fujitsu fi-5900C Pass-Through Scanner
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Hi I'm getting a lower case "c" error code on my fi-6130z. Anyone know what might it be?
Hello Steve,
The flashing "c" on your fi-6130z scanner panel indicates that the ADF was opened when the status was ready("1"). To return to ready("1") status, close the ADF. If the display doesnot return to ready ("1") after closing the ADF, turn the power off then back on. If the problem still persists, you are recommended to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Thanks & regards,
ScanCare
Aug 08, 2013 | Fujitsu fi-6130z - Document scanner -...
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
I need a solution to u1 error with detail code o5A in fujitsu fi-5900c scanner
Hello Marcus,
In Fujitsu fi-5900c scanner, Error 05a refers to JAM1 Sensor malfunction.You need to clean the two lenses of the JAM1 sensor with a cotton swab. Then check the performance of the sensor and also check sensor cable connections. This error also occurs if Pinch Roller 2 is installed left-right reversal. Check the same too. If the issue still persists, then you may have to replace the sensor.
If the above steps do not help, then you are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Feb 07, 2013 | Fujitsu fi-5900C Pass-Through Scanner
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
Keep getting a 'P'' on my LCD will not accept any scannering
Sometimes the feed switch gets knocked out of position
Aug 18, 2009 | Fujitsu fi-5530C Scanner
good luck
Jan 09, 2009 | Fujitsu fi-5530C Scanner
Scanner Display Shows False Jam
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 15, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-5530C Scanner Logo
1,042 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
