Question about HP PSC 950 All-In-One InkJet Printer
I am trying to print invitations on 5.5 x 8.5 paper
The hp psc 950 will not print the invitation in the center of the paper. It prints as if it has 8.5 x 11 paper in the paper tray. PLEASE HELP!
  • Anonymous Feb 15, 2009
    the printer keeps printing it on the side of the page not the center
  • Anonymous Apr 19, 2009
    Mine also prints on the side
  • 10 Answers
SOURCE: print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Posted on Oct 06, 2007
  • 15 Answers
SOURCE: Print Size
you have to choose the paper type in the printer driver option wheather envelope or A4 paper see the preview before printing
Posted on May 05, 2008
  • 6 Answers
SOURCE: Can't Print Invitations
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
SOURCE: How to print 5 X 8 invitations on an HP Photosmart C309a printer
I think it's more or less the same on Mac or PC. Hit Print in your software, then when the dialogue box comes up you should see several options settings. There will be a pull-down menu that lets you choose paper size. (This menu is sometimes buried in another sub menu called "printer options" or something similar. It can be tricky to find this in some apps like Photoshop). Just select your 5x8 size and then at the top of the dialogue box you should be able to save it all as a preset. Pull down the "preset" tab and select "Save As..." then you can name it and pull it up each time later.
Hope this works.
Posted on Mar 28, 2010
  • 1705 Answers
SOURCE: printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Posted on Apr 22, 2010
Invitations printing off center
You need to ensure that you are setting the program and driver for the correct size of paper. The paper does not need to be centered, the software just needs to start printing in the right place.
Sep 24, 2016 | HP HEW CN217A PHOTOSMART PLUS B210A...
Printing 5x7 card stock in HP 1510 injet all-in-one printer
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
Hope this works.
Oct 28, 2009 | HP Photosmart Premium C309A All-In-One...
I am trying to print onto 5.5w x 8.5h invitation paper. What settings do I need to use? If I select the paper size and put it in the printer, it will not print .... expecting regualar size paper.
Have you tried the upper level tray of your printer?
Go to the Print command
Select Properties
Go to paper source
Select upper tray (Be sure tray is loaded with paper)
select OK,
select OK
Jul 14, 2009 | HP PSC 950 All-In-One InkJet Printer
Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Apr 16, 2009 | HP Officejet 6310 All-In-One InkJet...
HP PSC 1310 reads paper jam in control panel. There is no paper i
Click this link to solve your paper jam problems with your HP printer:
http://bit.ly/9ShIi2
Mar 12, 2009 | HP PSC 1315xi All-in-One Printer
Paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Print Size
Mar 22, 2008 | HP Deskjet 3915 InkJet Printer
Print 5x7 invitations on my 950?
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
1,862 people viewed this question
Ben Johnson
