Question about LG WM-2277HW Front Load Washer
LG washing machine
I have a LG washing machine model WM2277HW, The machine is just out of warranty. The problem is that it is not responding to the start button. The last load done must have kicked the circuit braker, I have reset set it and have checked that there is power at the machine and that the water supply is o.k. per the troubleshooting guide. Thank You for any help
  • 3 Answers
The Play/Pause button? Check if you have Child Lock on? (Hold the Pre Wash button for three seconds to turn it on or off.
Posted on Mar 14, 2007
I have a LG front load washer model #59WD1653 LG WM2277HW I keep getting an error message of LE I have misplaced my Manuel. What does that mean
Google is not your friend, but can still be helpful.
https://www.manualslib.com/manual/409239/Lg-Wm2277hw.html
May 30, 2017 | LG Washing Machines
WM2277HW LG Tromm washing machine won't start. Finding correct parts is not so easy. Why?
At 14+ appliance years of age, it doesn't make economic sense to repair it.
Mar 06, 2017 | LG WM-2277HW Front Load Washer
Need to see diagrams for removal instructions for the drain pump on lg washing machine wm2277hw
LG WFS7012ds model washing machine while starting of washing operation after start 5 min machine geeting stopped with beep sound
Jun 21, 2010 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
LG front load washer WM2277HW. ''LE'' Error code
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jul 03, 2009 | LG Washing Machines
I need the user manual for my lg tromm wm2277hw because I don't know how to get it to spin without going through the whole wash cycle
for a drain and spin : turn unit on hit spin Button 1 time then start/pause button
this a drain and spin only..
Jun 15, 2009 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
523 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
